Cleaning Valves
Old Mar 26, 2011 | 11:31 AM
NocTurNalFX's Avatar
Icon2 Cleaning Valves
Im in the process of putting in a new head gasket on my 94 LS. I have the head off the block. Giving everything a good cleaning before reassembling. Whats the best way to clean all the carbon buildup on the valves and pistons?
Old Mar 26, 2011 | 11:46 AM
Chunkaroo!'s Avatar
Default Re: Cleaning Valves
When me and my friend put together one of my other friends engine we used picks to scrape of the carbon of the valves and then cleaned them with wire brushes and gasoline and it came out *******
Old Mar 26, 2011 | 12:08 PM
Ill try soaking some gas on them. brake cleaner does nothing. Thanks for the reply!
Old Mar 26, 2011 | 12:47 PM
Dogginator's Avatar
Daisy... Daisy...
Solvent is not going to remove carbon. A torch with an oxidizing flame will remove carbon, but subjecting the valves to that temperature is a bad idea. I would try to polish them with a brass brush.
Old Mar 27, 2011 | 12:09 AM
igorka_91's Avatar
Try seafoam. Did the job for me or just bead/sand blast them.
Old Mar 27, 2011 | 12:09 PM
Scooooter7's Avatar
Get a valve job done, you'll be glad you did.
scarney
Aug 22, 2009 09:15 PM
vtecn8ive
Sep 19, 2008 01:23 PM
jdub db8
May 4, 2004 08:32 PM
BlueShadow
Mar 29, 2004 04:57 PM
KooK
May 22, 2003 07:23 AM
