hondata s200 wont start
i got a hondata s200 on a p28 ecu when i try to turn on the car it give a solid red light but the car do turn on after a while it starts to smell like gas. some one told me that it might be cuz the s200 had too aggrassive tune for my car i tried it out on a bone stock d16z6 and the tune on the hondata s200 was for a fully built b20v would that cause it to not turn my car on or is the ecu damaged?
The s200 system you are using could have been tuned for aftermarket injectors or a wide variety of things, you can't just plug an ecu in from one car into another unless you know exactly what the ecu is tuned for (injector size, engine setup etc).
yea it was tuned for bigger injectors and for b20v. i was just trying it to see if it work i wasnt going to run it with my car just like that. but i found the problem it was my car that wouldnt start then i plugged in the ecu with the hondata s200 and it turned on right way.
yea i just wanted to see if the hondata s200 and the ecu were in working condition and they are. im goin to order a chip for my set up from your website within the next week hopefully. all i have to do is remove the chip thats in there right now and pop in the one i buy for my setup right?
turbodcxbro
Engine Management and Tuning
Jan 9, 2010 11:31 AM
