94 H22a 94 eg
Old Mar 25, 2011 | 08:06 PM
hatchman_34's Avatar
Default 94 H22a 94 eg
It starts up and idles between 800 and 1200 slowly...vacuum leak somewhere ...BUT there's gas coming out the tailpipe enough to leave a wet spot on the ground after about a min or so and smoke
Ive checked ohms and volts in both o2 sensor and my injectors is 11.5 normal?
Any suggestions are helpful thanks!
Old Mar 25, 2011 | 08:10 PM
farfrumugen's Avatar
Default Re: 94 H22a 94 eg
are you sure the wet spot is gas?
water is common from exhaust. light it on fire...see if it burns..lol
adam
Old Mar 28, 2011 | 09:49 PM
lol yea pretty sure its gas smells like gas plus i have gas in my oil so its not burning it correctly gonna check my map sensor
Old Mar 28, 2011 | 09:51 PM
LTCxD2B's Avatar
do prelude come with low impedance injectors if so would too much voltage cause them to lock open
is the car miss firing or almost cutting off
Old Mar 28, 2011 | 09:54 PM
raidacaipo's Avatar
Information on the fuel pressure regulator, fuel pump please..
Old Mar 30, 2011 | 04:48 PM
they're just stock injectors i believe saturated? no resistor...and i just have a stock fpr and fp...i tested my map sensor and im getting readings that aren't correct gonna switch that out and test my tps hopefully that solves somethings! thanks oh yeah and LTCxD2B it is is backfiring and it cuts out if i give it gas
Old Mar 30, 2011 | 04:58 PM
raidacaipo's Avatar
This is typical but make sure your tps and map sensor wires aren't switched up. They both look alike btw
Old Mar 30, 2011 | 07:17 PM
they're not^i doubled checked earlier...does anyone know where i can buy a dealers manual or something with really good detail on wiring more then a Chilton/Haynes?
girl_driven
May 2, 2016 10:22 AM
EJ-1
20
Nov 17, 2012 09:04 AM
TurboCivicR93
Oct 17, 2011 06:05 PM
92integraVTECgsr
Oct 16, 2005 10:26 PM
servion
Jun 10, 2003 02:40 PM
