96 civic issue
i have a 96 honda civic 1.6 vtech and when i start it up the rpms go straight to 2000 and does not idle down i changed the tps bc before it would got from 500 to 100 and up and down so i changed that and it stopped doing that but it idles high, it has no vacuum leaks, and if im driving in any gear when i give the gas it cuts out every now in then and bogs way down and in 5th gear it has no power what so ever any ideas on what could be causing this i can upload a video if that helps
ok i know wat cel is my bad i just put it on there and left the bolts snug and moved it as needed i need to get my oms meeter and check the wires i was looking on the fuel rail and there is a round thing with a clear cap on it where the main gas line bolts on i popped the cover off and a screw fell out that had a small o ring on it idk what that is ?
the screw in this piece was not in there would that cause it to cut out it has an o ring on there and i put it in there and tightened it up and it don't seem to cut out now but ill check it out tomorrow i have a link to a video so you can see what the idle does if i move it to where it quits doing the pulsating then its way to high
also the V-tech solenoid was un hooked for some reason
here is the link
http://www.youtube.com/watch?v=FeBd6mlGPe0
here is the link
Sambo 92
Jan 6, 2016 05:26 PM
theschweizer
Apr 21, 2015 05:42 PM
esurds
Jul 13, 2009 09:33 PM
