ep3 jrsc surging
Old Mar 24, 2011 | 12:38 AM
leighregan's Avatar
Default ep3 jrsc surging
car is surging up5k checked the idle control valve thats fine and checked all the bolts on the mainifold they are tight any ideas where the vacuum leak could be coming from
Old Mar 24, 2011 | 03:18 AM
lazlong's Avatar
Default Re: ep3 jrsc surging
Check real good for a vac leak around the throttle body gasket, around the PCV, and the brake booster hose. Check for a binding/loose throttle cable or binding/loose throttle plate. Put a scan tool on to see if any codes come up and if you have live data feed check throttle position-about 10% at closed throttle and 90% when at WOT.
Old Mar 24, 2011 | 03:58 AM
mustclime's Avatar
I had the same problem...the coldstart/ air injection valve had cracked and was letting air in all the time.....check that stupid peace of plastic that cost around 90 bucks.
Old Mar 24, 2011 | 09:09 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
just eliminate that stupid piece of plastic lol
Get some soapy water and spray down the enjoy... watch for bubbles!
crxnonvtec
22
Sep 3, 2009 02:52 PM
kilab16a
Sep 27, 2007 07:36 AM
91 ef hatchback
Jun 9, 2007 11:26 AM
DeDonDeRosa
Dec 22, 2002 06:14 AM
DeDonDeRosa
Dec 22, 2002 06:13 AM
