Slow drain on my battery.....
Old Mar 23, 2011 | 08:12 PM
si_motor_spt's Avatar
Default Slow drain on my battery.....
Hey all, my 00 civic ex has a diehard battery i purchased back in 06 and it has drained several times before(forgetting the lights on,etc) but i noticed lately when i go to work then leave (roughly 8 hrs) and i try to start my car, it jus barely starts so i dnt know if its just time for a new one or if thiers a drain, how would i be able to check the battery if theirs a drain?
Old Mar 23, 2011 | 08:17 PM
Former User's Avatar
Default Re: Slow drain on my battery.....
Start by having the battery tested. That's likely the problem.
If it's fine, then test for parasitic drain.
Old Mar 24, 2011 | 08:09 PM
Got a new battery so i'll keep u guys updated to c if anything changes.......thanks again ronj@ht
Old Mar 24, 2011 | 08:26 PM
Domani99's Avatar
Had the same exact problem in my civic. Had the battery less than a year. Even the test came back the battery was good. But eventually i got sick of it and bought a new battery. Problem went away. Only thing on with when my keys are out was my alarm. and i know that wasnt enough to drain the battery.
Old Mar 25, 2011 | 03:47 AM
donna's Avatar
My trunk light was staying on.
Old Mar 25, 2011 | 05:27 PM
NOFX's Avatar
H-T White Ops
This might help you in your own garage. I know shops use different equipment, but i don't expect you to buy a bunch of expensive equipment or bring it to a shop to trace your electrical issues (which can get pricey). Measuring Parasitic Current Draw
I had a similar issue and it was reliving to find out there wasn't a parasitic draw to trace, but at the same time it sucked that I still didn't know what the problem was.
Mine ended up being that my battery ground was bad. I could drive the car around no problem for a month or so, but then the car would die or just not start. I went through batteries and alternators several times as bandaids before I figured out what the problem really was.
Old Mar 26, 2011 | 05:46 PM
Kwilliams6's Avatar
My cluster light stays on when the car is off and its slowly draining the battery. i have a 99 civic si. Everything was fine until the car wouldt start and i found the rubber wasnt connecting all the way under the clutch after that cluster light stays on when i turn the car off. Can any help plz
Old Mar 26, 2011 | 07:19 PM
Domani99's Avatar
what is the rubber under the clutch thats not connecting all the way?
Old Mar 27, 2011 | 09:59 AM
thanks everyone for everyone for the inputs, great stuff, ya i had to settle for a fricken quickstart battery, i was tryn to look for an odyysey or optima battery but like always either none or way to damn exspensive
Old Mar 27, 2011 | 10:04 AM
NOFX's Avatar
H-T White Ops
I had an Optima. Won't ever happen again. Biggest pain in the *** battery I've ever owned. I swapped mine out at least three times, couldn't get my money back, so I put it in a car I was selling and let it go that way.
Old Mar 27, 2011 | 10:09 AM
Domani99's Avatar
What happened? I was thinking about getting an optima as well
Old Mar 27, 2011 | 10:10 AM
grumblemarc's Avatar
The Grumpiest
I'm regretting it. I don't drive the car often as I work from home. Battery seems to lose it's charge within 3 days.
Old Mar 27, 2011 | 10:12 AM
Domani99's Avatar
Ya sometimes I don't drive the car for datlys at a time. What battery would be good for that. Only have the alarm light on for those days
Old Mar 27, 2011 | 10:34 AM
SeanK325's Avatar
for one, they don't have a long warranty. they're expensive, so once they go out you are more than likely not going to get a pro-rated discount.
Old Mar 27, 2011 | 10:57 AM
NOFX's Avatar
H-T White Ops
The battery would just die repeatedly. One manager at Autozone theorized that the car could not manage to maintain the battery.
I had problems when I daily drove my car and then also problems when I bought another daily driver. that battery would die even if I drove it every day of the week.
All I know for sure is I went through three of those pieces of ****. It was a red top. I had a customer complaining about them yesterday as well. He says in the military they use them. They just have a pallet of them though so when they go out (which is often), they just grab another from the pallet.
Old Mar 27, 2011 | 11:00 AM
SeanK325's Avatar
from my experience, Interstate batteries last the longest.
if you're on a budget and have a Costco membership, I've had great luck with their Kirkland batteries.
Old Mar 27, 2011 | 11:03 AM
The Grumpiest
Any opinions on Braille before I research?
Old Mar 27, 2011 | 12:10 PM
Kwilliams6's Avatar
THERE IS A PEICE BY THE CLUTCH (DONT KNOW THE TERM) AND IF IT DOESNT TOUCH WHEN YOU SINK THE CLUTCH THE CAR DOESNT START. MY GUAGE/CLUSTER LIGHT STAYS ON WHEN THE CAR IS OFF AND NOW ITS DRAINING THE BATTERY.
patrickstar
Audio / Security / Video
Jul 15, 2009 04:38 PM
Integ-boy
Nov 26, 2007 06:12 PM
EM1onBOOST
Apr 3, 2007 12:19 PM
SpoonEk253
Nov 26, 2006 02:12 PM
s2kkk
20
Apr 1, 2004 12:54 PM
