Nearly complete steering modification/maintainence NEED HELP
Hey HT I'm installing new tie rods(inner&outer) as well as putting new boots on. I'm also planning on changing out my pinion and gear for this integra ones; it changes the steering ratio apparently. My question is what else suld I replace along with these things? I just installed a new p/s pump btw
Fluid....lol Not much else to go with the rack cause your doing everything. Check your lines is the only things left.
