remote starter
hello, i recently hooked up a remote starter. the bulldog rs 1200. thing is i got everthing to work. when i go to unlock the door, it triggers the alarm. and i have to use my key to shut the alarm off. they say im suppose to hook the factory alarm shut down(FASD) WIRE up to the, "on the LX Model the wire is located at the KEYLESS/SECURITY Module attached to the DRIVERS UNDERDASH PANEL. " this wire is suppose to be blue. but i just cant locate it. i seen three blue wire down there. a blue/black wire,blue/white wire,and a babyblue wire. so im confused. which or where am i suppose to locate wire.?
Try the baby blue. Set your meter to DC, connect the red probe to your baby blue wire, the black probe to ground. You should see voltage on the baby blue wire (most likely +12, but could be less). Take your key, stick it into the drivers door cylinder and turn it to "unlock" the door and HOLD IT in the unlock position. If it's the right wire, the voltage will drop to 0 (or 0.x)
Other than that I can't be of more help because I don't know what year Accord it is...
Try the baby blue wire, it should be the right one if you can trust the directions you have. If that doesnt help it could be a bad connection somewhere of feedback coming threw. Props on doing your own alarm, some can be challenging.
Hope this helps
Alex R.
Hope this helps
Alex R.
btrotter
Nov 21, 2016 04:14 AM
Civic Type-R
May 14, 2003 03:07 PM
