Has Anyone Swapped Motor Mounts Without A Hoist?
Old Mar 23, 2011 | 01:25 PM
91GEDHATCH's Avatar
Default Has Anyone Swapped Motor Mounts Without A Hoist?
I'm thinking I can put a support or jack under the engine, and change them out one at a time. Has anyone attempted this or found some other trick? I can't afford a lift at the moment but I'm itching to get my new mounts on ha ha!
Is there a certain order to go in that would make it easier?
Thanks!
Old Mar 23, 2011 | 01:34 PM
KINGVEM^^ED6's Avatar
Default Re: Has Anyone Swapped Motor Mounts Without A Hoist?
Iv seen ppl use a jack with a 2x4 on it
im thinking of doing the same ****
Old Mar 23, 2011 | 02:06 PM
91GEDHATCH's Avatar
That's what I had in mind, but is the oil pan going to support that weight?
Old Mar 23, 2011 | 02:11 PM
ef yu's Avatar
i have used a 2x4, placed it underneath the pan and jacked it up slowly. worked for me without putting a dent. just make sure the jack isnt focused on one spot. try to distribute the weight.
Old Mar 23, 2011 | 02:15 PM
maybe two jacks right next to each other and two 2x4s \\op were u live
Old Mar 23, 2011 | 02:43 PM
Orangegsx's Avatar
2x4 layed flat and a jack works fine.
Old Mar 23, 2011 | 06:11 PM
Sancho815's Avatar
the oil pan will support it fine. had a motor drop about 7 inches off the ground straight on the pan. it had no dents
Old Mar 24, 2011 | 06:50 AM
90efhatch's Avatar
I have done it this way for many years and I have never dented an oil pan. Just make sure that the 2x4 is long enough to disperse the weight across the pan.
Old Mar 24, 2011 | 08:01 AM
Surfjunkie44's Avatar
x2 - This is actually the procedure the Chilton's manual recommends... not that I put a lot of stock in the Chilton's manual.
Old Mar 24, 2011 | 08:28 AM
.Manny.'s Avatar
Touching My Member
I did it yesterday. Took out my mounts, let it sit overnight with a couple of pieces of plywood holding up the engine, had innovative press in new 75A bushings (lifetime warranty FTW) and popped them back it. It was cake.
Old Mar 24, 2011 | 09:22 AM
wha im gonna have to do this asap when i get back my motors shaking like a hot *** in the club
Old Mar 24, 2011 | 01:45 PM
91GEDHATCH's Avatar
I'm in Nashville TN.
Awesome! I'm glad everyone stands behind the "cheap" way of doing it. Goin to attempt it today.
Old Mar 24, 2011 | 01:52 PM
91GEDHATCH's Avatar
Sorry, not meaning to continuously bump, but when changing them, is there a better order in which to swap them out? Thanks.
Old Mar 24, 2011 | 02:36 PM
4drEF's Avatar
Keyboard Humorist
I absolutely HATE the front mount on the stock D motor.
The procedure includes removing the exhaust manifold to get at the bolt.
That's the one I would do first just to get it out of the way.
Old Mar 24, 2011 | 03:02 PM
91GEDHATCH's Avatar
Whoops, sorry completely forgot to mention its a B18 under the hood...
Old Mar 24, 2011 | 03:09 PM
lol so your not even running a front mount right
stock d mount in the front is a bitch i did it with clipsed help with out removing the header
Old Mar 24, 2011 | 05:05 PM
4drEF's Avatar
Keyboard Humorist
How in the world did you get that long bolt out?!?!
Lucky you!
Old Mar 24, 2011 | 10:35 PM
.Manny.'s Avatar
Touching My Member
I do the rear first, then tranny, then driver's side.
Here's a shot of my new bushings. ;-P
Old Mar 27, 2011 | 03:30 PM
91GEDHATCH's Avatar
Ha ha... yeah no front mount for me this time around.
Old Mar 27, 2011 | 03:36 PM
idk it just worked man i thought it was gonna be a bitch but it worked hardest part was lining up the mount and bolt lol
Samsham
Honda CR-V & Element
Aug 15, 2017 04:56 AM
OmgDelSol
May 8, 2013 02:53 AM
01-0041
16
Sep 23, 2008 03:46 PM
morebhp
11
Feb 12, 2008 10:36 AM
SFC
Sep 13, 2004 02:47 PM
