Transmission & Drivetrain Gearboxes, Differentials, Clutches
B-Series diff question
Old Mar 22, 2011 | 08:29 PM
ALL MOTOR DA's Avatar
Default B-Series diff question
ok so i have two diff here one from my s80 ls tranny an another from what the seller so called a ys1 with LSD. now the question is both final gears have 64 teeth the s80 has 2 notches on the ends of the teeth but the lsd doesn't have any notches. so could i still put the lsd an the final drive in my tranny? (of course with a lil grinding on the case)
Old Mar 22, 2011 | 09:00 PM
Aquafina's Avatar
Default Re: B-Series diff question
Keep the FD (ring gear and countershaft) matched.
Old Mar 23, 2011 | 09:20 AM
the LSD counter shaft are b16 gears i would like to keep my ls. (plan on goin turbo soon), an whats the diffrence with the notches on the ends of the teeth what's that for.
Old Mar 23, 2011 | 01:45 PM
Gearspeed-Performance's Avatar
Do both of the final drive gears have the same bolt pattern or does the YS-1 have a factory viscous type LSD that has a different bolt pattern? If it does have a different bolt pattern..than no you cannot. If it has an aftermarket LSD that uses the same bolt pattern then you can swap them as a MATCHED SET. Let us know what you have.
Old Mar 23, 2011 | 03:17 PM
diffrent type of bolt pattern.
Old Mar 23, 2011 | 03:23 PM
Unfortunately the LS final drive will not work with that LSD =( What ratio is that LSD ring and pinion?? If so why not use the LS S80 gearing with the LSD ring and pinion?? I am guessing the YS-1 you pulled that LSD is a short geared YS-1??
Old Mar 23, 2011 | 03:32 PM
yeah was told it was short geared. i have the lsd counter shaft an main shaft. but i wanted to keep the longer gear ratio.
Old Mar 23, 2011 | 04:12 PM
David @ Synchrotech's Avatar
If the ring gear on the viscous LSD has 64 teeth then it is not from a YS1 since the YS1 OEM LSD only came with a 66 tooth ring gear. It is probably from a Y1 earlier model. The Y1 countershaft has different splines and will not fit with the YS1 gears. The tic marks on the tooth face are the marks from Honda used to ID the gears. The ring gear must be used with the matching countershaft so unfortunately it will not work. Post some pics of the countershafts and I will let you know for sure.
Old Jun 12, 2011 | 12:40 PM
back from the dead
Old Jun 12, 2011 | 01:00 PM
^^This is a Y1 viscous LSD and will not work in a YS1 transmission.
Old Jun 12, 2011 | 03:08 PM
in what other tranny or how would i be able to use this.
ALL MOTOR DA
Mar 23, 2011 12:31 PM
sk8shorty012
May 31, 2006 11:30 PM
Dunc
Jun 14, 2005 04:17 PM
eg6ajk
13
May 11, 2004 07:50 AM
dc2lun
Dec 17, 2003 06:09 AM
