01 Civic EX Speedometer/dash not working
Just bought a 01 Civic EX 4 door a few months back. Everything was working fine when I bought it. The complete dash now isnt functioning. The weird part is that sometimes it does work . But randomly. I have no clue where to start. At first I checked all the fuses thinking that was it. But they are all good. Like I said it randomly works. :/
If you have an aftermarket radio look behind it at the wires to see if something is loose or shorted. There's also a TSB about the combination switch for that year- check the sticky. Other possibilities are a short in a wire somewhere or a bad MCU (it's in the under-dash fuse box).
I bet that's the problem. The brightness control for the dash runs thru the stereo. Look for loose connections. FYI: MCU- Multiplex Control Unit
Im thinking it gonna be the MCU. Like I said it works when it wants to. But the battery fuel light and trunk light on the dash dont ever work. But I have seen them just come on out of nowhere. Im gonna look into changing the MCU as soon as I find one. Will post as soon as I do.
