Rocker arm installation?...
Old Mar 22, 2011 | 06:02 PM
Edwin909's Avatar
Default Rocker arm installation?...
I need help installing a rocker arm in my b16a head I bought a few rocker arms but there all over the place is there a specific place certain rocker arms belong in any info would help
Old Mar 22, 2011 | 07:13 PM
KINGVEM^^ED6's Avatar
Default Re: Rocker arm installation?...
grab a helms manuel for the 2000 civic si with the b16 im sure that will be able to help
Old Mar 22, 2011 | 09:31 PM
prelude182's Avatar
you should have layed them out accordingly after you disassembled it, unless thats how you bought it.
Old Mar 22, 2011 | 09:33 PM
Edwin909's Avatar
Where can I buy one of those
Old Mar 22, 2011 | 09:51 PM
Edwin909's Avatar
That's how bought them so I'm guessing certain rocker arms belong in a specific place on the head
Old Mar 22, 2011 | 10:02 PM
*JDM*Ej8*'s Avatar
the bigger vtec arm goes in the middle and the two valve rocker for when ur not in vtec have two gold pins those sit inside the middle vtec rocker theres only one way they will fit in there correct positions. just put the two outer ones with gold pins so that the gold pins are in the vtec arm and put the rocker arm shaft in
Old Mar 23, 2011 | 01:43 AM
Edwin909's Avatar
I already knew the bigger rocker arm belongs in the middle but the two smaller ones are in fact different I need to know which one goes on the right or left and I keeping hearing about placing the rocker arm unit back to the same position it belonged in but I have no idea where it belongs if i bought the all scrambled up i just need to know if you do indeed in to place the rocker arm unit back to where the belonged originally or if what i heard was just to be on the safe side?...
Old Mar 24, 2011 | 01:14 AM
explicite86's Avatar
in general, yes, rocker arms should be removed and placed back in their original position. for instance http://www.flickr.com/photos/1461693...n/photostream/ the rocker arms in the red circle belong to the number 4 cylinder on the intake side,, and the rocker arms in the blue circle belong to the number 1 cylinder on the exhaust side. Each set of rocker arms has a specific wear pattern so they should be re-installed where they were IF you know where they came from. And if not it wont break or ruin your engine technically. 2nd,, you can tell which outer rocker arm goes on which side by taking a close look at them. There is a little metal pin that sticks out on one side of the rocker arm, it only sticks out a quarter inch or so and is about the thickness of a push pin,, the side that has the little metal pin sticking out of it goes against the middle "VTEC" rocker arm, like so... http://www.flickr.com/photos/1461693...n/photostream/ ...let me know if this helped clear things up and feel free to ask me any questions you have.
Old Jun 21, 2012 | 07:42 PM
jhanif63's Avatar
HELLO, I HAVE 1990 HONDA CRX AND I NEED THE TIGHTING SEQUENSE FOR THE ROCKER ARM ITS GOT 16 VALVE
Legion
Aug 22, 2007 02:34 AM
Renegade
Jul 3, 2006 11:46 PM
Nic
Oct 14, 2004 02:31 PM
len
Jan 19, 2002 06:56 AM
