Si Transmission question.
Old Mar 22, 2011 | 03:47 PM
WinstonSmith's Avatar
Default Si Transmission question.
I recently ran into transmission issues with my 91 4 speed Ef civic. (Multiple bearings - squeaked like a barrel of squirrels). Honda technician found out the issue.
http://www.ht-archive.com/showthread.php?t=2894682
I thought about replacing the bearing completely but, I was offered a 91 Si transmission free of charge (PL3/3000).
I've done my research and to my great surprise it's a direct bolt in.
Well as I was looking over the Si transmission I noticed a crack in the bell housing.Looks like it may have been dropped.
I've included a picture. Will this be an issue? Or can I run it with the crack in it?
Thank you.
Old Mar 22, 2011 | 04:27 PM
Default Re: Si Transmission question.
I was hoping to swap it in this weekend.
Any help would be appreciated.
Old Mar 22, 2011 | 06:02 PM
Anyone?
Old Mar 22, 2011 | 06:05 PM
KINGVEM^^ED6's Avatar
your gonna need a better pic then that bro
Old Mar 22, 2011 | 07:09 PM
How about this video?
http://www.youtube.com/watch?v=ED-nlRZCTQg
Old Mar 22, 2011 | 07:23 PM
personally id run it or you can always pull out the internals and swap it into your four speed case
Old Mar 22, 2011 | 07:44 PM
Awesome thanks.
I'm thinking about having a piece to cover it.
Just so nothing flies in randomly.
Old Mar 23, 2011 | 12:00 AM
stackedhouse's Avatar
id swap internals over... but covering it would be easier
Old Mar 23, 2011 | 07:26 AM
jlk16188's Avatar
run it. it was free
Old Mar 23, 2011 | 08:22 AM
Projekt_Ef9's Avatar
I would cover it and run it.
Old Mar 23, 2011 | 03:13 PM
hondacivicracer's Avatar
ya just cover it up and run with it if anything seems out of place then stop quikcly but swapping a tranny in and out is hella easy plus you can find them all over
Old Mar 23, 2011 | 04:55 PM
also make sure if you have a 88 that the trans is a 88 or if you have a 89-91 you can use a 89-91 tranny 88s different
Old Mar 23, 2011 | 05:41 PM
I have a 91' and it is a 91'si transmission.
Old Mar 23, 2011 | 06:50 PM
[Ennis_D]'s Avatar
Good luck swapping over the Si internals -> the 4spd case:
Originally Posted by Aquafina
The Si internals will work fine.
The 4spd is a 5spd trans with a few changes: spacer collars in place of 5th gear and 5th gear sleeve assembly, different shift fork rods and no 5th gear shift fork, no reverse lockout.
Swap the gear stacks and ring gear to the 4spd case along with the shift fork assembly and add the reverse lockout in. You'll need to shim the mainshaft.
All from here: Gearset & Final drive compatibility among cable D-Series transmission cases
Old Mar 23, 2011 | 08:40 PM
I'm just going to cover it.
Swapping the case would be a fun project. But I don't have the time to do all of that.
ninoner3377
May 30, 2013 05:40 AM
mistermayo
13
Jul 17, 2003 06:53 PM
