Plastic gauge. to many bearing colors...
Old Mar 22, 2011 | 02:49 PM
nonpoint986's Avatar
Default Plastic gauge. to many bearing colors...
Ok, so my entire problem started with me finding metal shavings on my mag oil drain plug. I took my turbo off and found out that it was garbage and the exhaust turban wheel was grinding on that metal cover/seal thingy . well, one piece of crap got into the oil galley of one main bearing and started a slight knock. very little. so now im going to plastic gauge and do ALL the bearings over again and make sure they are right from the start, mains and rods.
I think all b series bottom ends are the same? I dont know what color is the standard size, so i can order some and have a place to start.
b20b bottom end. turboed at 450 hp. ( if that helps )
http://www.bkhondaparts.com/billkay/...itch=&hidIrno=
Old Mar 22, 2011 | 03:14 PM
Default Re: Plastic gauge. to many bearing colors...
crap... just thought of this. is a vtec engine going to have different bearings than a non vtec engine. i previously have some acl ones... untill this stupid knock problem. I rev the motor up to 8500 rpm. not all the time, or when the tires break loose it revs that high LOL
RACEPAK
Welding / Fabrication
Dec 11, 2010 06:21 PM
thomas188
Aug 8, 2007 06:24 AM
Dublocivic
Dec 6, 2005 06:39 PM
calizum
Jun 8, 2005 07:36 AM
turbociv
15
Mar 11, 2004 01:16 PM
