what rack do i have?
Old Mar 21, 2011 | 05:30 PM
Street_sleeper's Avatar
Default what rack do i have?
bought this ek which is a 96 dx but it has power steering now the pressure line is just leaking like a beach. how i tell what line i need em1 has one option and the 99-00 dx have two options... any way to tell them apart?
Old Mar 21, 2011 | 05:35 PM
Default Re: what rack do i have?
or anyway to the pipes have part numbers?
Old Mar 22, 2011 | 12:56 AM
NOFX's Avatar
H-T White Ops
Pics might help.
Honda likes to use loads of different part numbers (could be a different manufacturer, slight update of a design, different material, etc. even) when other companies selling OE replacement type parts might use only one part number.
I've noticed that even parts that appear to be the same and function the same can have two different part numbers. For example, the front lip for the Si (standard) versus the optional one for the other coupes. Even with the same color selected, the Si one is listed as pricier. No idea why!
The DX hatch had optional power steering, but I'm not sure how common it was. So there's a chance it's (mostly) the stock set up, but I'm not 100% sure.
Old Mar 22, 2011 | 05:58 AM
4cylfiend's Avatar
You have a nice rack.
Old Mar 22, 2011 | 08:09 AM
raverx3m's Avatar
indeed nice rack
Old Mar 22, 2011 | 08:10 AM
raverx3m's Avatar
check by vin number at honda dealership
Old Mar 22, 2011 | 09:39 AM
the civic is a 96 dx which did not come with power steering... now autozone has the same part number for 99-00 civic si and dx... but majestic have three different part numbers two for the dx and one for the si..
Old Mar 22, 2011 | 11:08 AM
NOFX's Avatar
H-T White Ops
More than likely they're all "close enough" then. By that I mean there is likely some difference, but it's probably something small or insignificant and the parts are interchangeable.
Old Mar 22, 2011 | 11:45 AM
should i bank on going with the si because of the dohc the line mite be a hair longer?
Old Mar 22, 2011 | 03:20 PM
ordered the si pressure line so cross my fingers it will work.
SiRay13
Suspension & Brakes
Mar 9, 2006 03:27 PM
Grams0wnsyouz99*
Nov 24, 2005 10:44 AM
GBRacing
Jul 2, 2005 06:18 AM
TEGPOWER44
19
Nov 26, 2002 12:21 AM
VTECTIME
19
Oct 19, 2002 07:47 PM
