Wiring Vtec into a 92 Cx
I need some help on wiring vtec into my 92 cx, i know i need to run wires from the solenoid and the knock sensor, but do i run then into the wire harnes or stright to the ecu? and what pins at the ecu do i use for the vtec and knock sensor? Email me at robest08@hotmail.com. Thanks Rob
ALL 92-95 Hatches are pre-wired for vtec. No need to run wires, only wire u should run is a knock sensor wire(if your doing a gsr swap).
[Modified by blykins, 4:05 AM 9/27/2002]
liam
You are incorrect!! All the 92s had wiring for VTEC. But the 93-95 only the SI/EX/VX had vtec wiring..the rest didnt.
liam
liam
Ok. ALL 92 models had Wiring for Vtec.
BUT 93-95 CX and DX did not.
Correct?
Correct?
honda said "wait! we can save 3 cents per car! take that vtec wire off"
liam
BLYKINS
if you don't know what in the hell you are talking about KEEP YOUR DAMN MOUTH SHUT. This is the Kind of **** that makes all the NooBs on here sound like IDIOTS. Because you are giving people WRONG INFORMATION. Damn if you don't know what you are talking about DON'T POST .
Only 92 Hatches WERE ALL wired for VTEC 92 model ONLY and that is the GOSPEL.
BLYKINS
BLYKINS
BLYKINS
[Modified by blykins, 6:03 AM 9/27/2002]
Not perfect but please don't give out misleading information. If you are not sure let them know what you think but tell them you arent sure.
[Modified by blykins, 6:08 AM 9/27/2002]
the 92 cx canadian version is wired for vtec...i cant remeber what pins exactly are the vtec wires...ill get back to you on that one if i figure it out...im not gonna guess cause i dont want to give misleading Info!!!!!
I may be wrong but I think If your car was made in Canada it is already prewired regaurdless of year. My 93 Canadian CX had a VTEC wire. All I needed was knock
Can anyone back this up on the Civic's from Canada? I need to figure out how to wire vtec in for my GSR motor when I get it
My stepbro has a 94 DX and it was made in canada, so he probably has a vtecwire already.
Yep your correct.
[/nelly]
on me
