Aftermarket steering wheel horn button
Old Mar 21, 2011 | 12:33 PM
95egianp's Avatar
Default Aftermarket steering wheel horn button
I have a Momo race wheel with a Momo hub. Is there any way to make my horn work? And is there any way to make it so that the button does not just fall right through the wheel? Seems weird that it would come with a horn button knowing it won't work. Any help is appreciated.
Old Mar 21, 2011 | 12:37 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Aftermarket sterring wheel horn button
Check the FAQs. I found this link there for 92-95. There's clarification in it for 96-00.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-how-wire-up-your-horn-aftermarket-wheel-eg-1485735/
As far as the horn button not fitting that makes no sense. You sure you have all the parts/correct horn button?
Old Mar 21, 2011 | 12:43 PM
95egianp's Avatar
The horn button came with the wheel, so i am assuming its the correct one.
Old Mar 21, 2011 | 12:56 PM
The Grumpiest
Don't see how if it doesn't fit. Is it a true Momo or a knock-off?
Old Mar 21, 2011 | 01:26 PM
95egianp's Avatar
I meant like, it fits but if you push with a little force on it, it falls through. It can stay there on its own, but if i could get the horn to work, i would like the button to STAY in place.
Old Mar 21, 2011 | 02:02 PM
The Grumpiest
Sorry. Sounds like you got the wrong horn button.
Old Mar 21, 2011 | 03:44 PM
95egianp's Avatar
Are there different sizes of horn buttons? If it was a little bit bigger then it wouldn't stay either, it would have nothing holding it at all.
Old Mar 21, 2011 | 03:53 PM
The Grumpiest
Did it come with a retainer ring? The ones I see on Ebay have a small or a large size horn. The NRG wheel I got fit perfectly-horn button and all.
Old Mar 21, 2011 | 08:03 PM
95egianp's Avatar
It didn't come with a retainer ring.
Old Oct 25, 2012 | 07:18 AM
JDM333's Avatar
Retainer ring comes with MOMO Hub not with steering wheel, without this ring horn will not stay in place. You can order retainer by itself PM me for part # info.
phoxking
May 6, 2012 01:51 PM
Dang EG
Sep 15, 2008 09:13 AM
2k3msp
Jun 23, 2008 10:26 AM
D3U1LT
Jan 8, 2008 10:03 AM
kos99ngel
Apr 6, 2007 10:03 PM
