what motor do i have ?
Old Mar 20, 2011 | 04:18 PM
aceclimb1's Avatar
Icon2 what motor do i have ?
ok i got a b16a full swap about a year ago and i seen that my motor looked diff. its obd 0 first gen and the motor is a 91 it say 91 on the head and its pr3-2 but i know thats just the casting numbers but on valve cover the VTEC part is bigger then the dohc part for the most part the valve cover is diff. then all the frist gen b16a i have seen can someone help here! i have been told the last few months of 91 honda want to the 2nd gen is this true ? o and the ecu is a pr3 and it hads a y1 trans and vtec kicks in at 5200 rpm and as far as i know it should kick in at 4900rpm not 5200rpm and it has not been changed its stock!! so can someone help please
Old Mar 20, 2011 | 04:24 PM
00siboy's Avatar
Default Re: what motor do i have ?
1) learn some grammar, it took me an hour to read that
2) what is your Q exactly? if u can see the #s on the block and head, then why don't u know what engine u have? are u just asking bc ur vc is different?
Old Mar 20, 2011 | 04:44 PM
D16SiHatch's Avatar
http://asia.vtec.net/topics/b16aver.html
also check the serial number below the engine code stamp
usually OBD0 Blocks start with a 1
and OBD1 blocks start with a 5
Old Mar 20, 2011 | 05:14 PM
aceclimb1's Avatar
thanks to D16siHatch thats helpful and it does start with a 5 but the dizzy and the ecu r obd0 , And to 00siboy i didnt come on here asking for u to talk about grammer but thanks anyways and im asking what motor do i have i order a 1st gen and it looks like a 2nd gen and its looking like the numbers r adding up to it being a 2nd gen thats what im asking can u under stand that or u need more ?
Old Mar 20, 2011 | 05:21 PM
KINGVEM^^ED6's Avatar
pics
Old Mar 20, 2011 | 06:11 PM
aceclimb1's Avatar
http://i31.photobucket.com/albums/c3...10320-2150.jpg
http://i31.photobucket.com/albums/c3...10320-2148.jpg
Old Mar 20, 2011 | 06:30 PM
crx_si-r's Avatar
Originally Posted by aceclimb1
Fixed
Old Mar 20, 2011 | 06:37 PM
aceclimb1's Avatar
thanks man
Old Mar 21, 2011 | 04:27 AM
aceclimb1's Avatar
any one ?
Old Mar 21, 2011 | 07:08 AM
dephtone's Avatar
The motor and head seem to be a 2nd gen one. You can use the OBD-0 distributor and a PW0 or PR3 OBD-0 b16 ECU and it will be fine.
If you are ordering parts, I have a stock 1st gen b16a and I always order parts from a 95-96 (I believe)Del Sol with the b16a3 or a 99-00 Civic Si with the b16a2 in it. All the parts fit, you just have to watch on ordering stuff for your transmission.
Old Mar 21, 2011 | 07:22 AM
aceclimb1's Avatar
no thats the way it came to me as obd0 dizzy was on there and came with a pr3 ecu obd0
Old Mar 21, 2011 | 07:36 AM
Goldo6606's Avatar
i laughed for about 10 minutes
Old Mar 21, 2011 | 08:16 AM
aceclimb1's Avatar
well people what is it a 2nd gen or a 1st gen come on, i payed for a 1st gen and im thinking i got lucky and got a 2nd gen
Old Mar 21, 2011 | 09:08 AM
if u paid for a first gen and got a second gen u came up they are just running it obdo all u would have to do is swap dizzzzys n ecu to run it obd1 sheesh
Old Mar 21, 2011 | 09:13 AM
dephtone's Avatar
You can see for sure which gen the head is by looking at this picture:
No one is going to be able to say about the block as there are people that have 99-00 b16a2's that have 5 million stamp as well. So just consider yourself lucky if you got a gen 2 instead. I mean you make out either way, it's not like you paid for the gen2 but ended up getting a gen 1. The only difference is ~10 hp due to the compression ratio being SLIGHTLY higher (10.4:1 as opposed to 10.2:1 in the first gen)
HondaCRXnewbie
Nov 21, 2012 04:54 PM
scartownhondaz
Jun 14, 2009 06:37 AM
crxnj
Apr 7, 2006 05:42 PM
BACKintheDA
Feb 26, 2004 09:10 PM
ejprimo
Jul 18, 2002 07:10 PM
