aftermarket fuel injectors with factory ecu
Old Mar 20, 2011 | 08:24 AM
dritan's Avatar
Default aftermarket fuel injectors with factory ecu
im rebuilding my engine and i found a set of fuel injectors for cheap. im planning on going turbo after i run the car n/a for a bit.. ie break-in procedure
will the aftermarket injectors work fine with a stock ecu? the car needs to be started then towed to a tuner but I'm not going to start the car with the obd2 ecu and load a base map just to start it.
ill swap in the obd1 + harness once im leaving for tuning
Old Mar 20, 2011 | 08:53 AM
Spawne32's Avatar
Default Re: aftermarket fuel injectors with factory ecu
no they will not, the stock ecu only knows how to run one time of injector, the fuel injector battery offsets will be wrong, and the car will run pig rich since they are bigger then the OEM injectors
Old Mar 20, 2011 | 09:49 AM
Gunmetal_B20_Hatch's Avatar
Wont work unless you have a chipped ECU and recalibrate for increased injector size.
How big are the injectors you are looking to buy?
Old Mar 20, 2011 | 12:05 PM
dritan's Avatar
oh i imagined that the stock ecu could calibrate the aftermarket injectors and work at whatever load the ecu is supplying to the injectors. i believe is 245cc
i got a great deal on id1000 injectors, there more than enough but I found them for 300 bucks
Old Mar 20, 2011 | 01:08 PM
Spawne32's Avatar
if you tried to start the car on 1000cc injectors you would just flood it out instantly and it would never run lol thats like trying to spray a fire hose with fuel in your engine
Old Mar 20, 2011 | 01:18 PM
Spawne32's Avatar
oh and to give you an idea of what im talking about, starting my car on the factory ecu tune with 420cc injectors installed, my AFR is 9:1 at idle
Violentpanda
Sep 11, 2018 02:57 PM
the rook
Oct 22, 2015 05:06 AM
Mark Hopper
Sep 16, 2013 12:38 AM
Fnix
May 17, 2012 03:04 PM
drzfamas718
Jan 12, 2010 12:17 PM
