speedo acting up, warning lights on...
Old Mar 20, 2011 | 01:24 AM
Kasta_JayDeeEm's Avatar
Default speedo acting up, warning lights on...
wtf is happening jump to around 1:30min and watch till end
Old Mar 20, 2011 | 01:46 AM
engtaz's Avatar
Default Re: FUUUUUUUUUUUUU
Weird, Have not seen that happen before. Wow
Old Mar 20, 2011 | 04:20 AM
djkurious's Avatar
What code are you getting? I see the engine light is on.
Old Mar 20, 2011 | 06:25 AM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
In the 5Th gen. which I have (1994-1997) and I recently purchased did the same thing, turns out the circuit board behind the speedo. was faulty, I swapped it out all was good.
I see yours is a 2000 accord, since your check engine light is on it could be your VSS sensor, remember if the circuit board is bad it won't trigger the check engine light.
The coolant indicator not working is likely an electrical short, checking your fuse would be the first step.
Old Mar 20, 2011 | 07:12 AM
TheMuffinMan's Avatar
He knows where you live!
Check Engine Light
SRS Light
and whatever the other indicator is
Have the CEL scanned, kidcool is most likely correct, if you have cruise control try to use that as well. If it doesn't work it is probably the VSS.
The SRS light and the other one concern me too however.
Old Mar 20, 2011 | 07:26 AM
phootbag's Avatar
All I see is an inop brake bulb.
Old Mar 20, 2011 | 07:38 AM
Nathan007's Avatar
I had this problem too, well for me it turned out two things;
First time, i noticed the insulation on some of the VSS wires was cut (near the sensor), allowing water and debris to come in contact with the wire. Fixed it, problem solved.
Second time, same problem, but at the connector. Had to replace the connector. Then i noticed the middle pin on the VSS unit was broken. Had to replace the VSS (Vehicule Speed Sensor).
You can try checking it out visually, it's not really hard (just badly located), it would be a start.
Old Mar 20, 2011 | 10:47 AM
my check engine light isnt on, when my speedo trips out my washerfluid light lights up and my engine temp gauge goes all the way down, my abs and srs light are on for a different reason, i recently brought my car to a local honda dealer where i ran the scanner on it
srs - air bag sensor underneath passenger seat is faulty
abs - rear driver wheel speed sensor needed to be replaced
im gonna check my VSS when i have free from work
Old Mar 20, 2011 | 11:25 AM
The little yellow light with the engine on it is not your CEL? Unless I'm smoking crack I think I see that solid throughout the video?
Old Mar 20, 2011 | 12:13 PM
nah bro look close its the washer fluid light(on the left)
abs and srs (on the right)
seat belt (bottom right) :p
Old Mar 20, 2011 | 03:13 PM
poorman212's Avatar
Ok, I wish I could believe that the CEL isn't on.....dude you have enough warning lights on that I personally would be worried about driving the car.....much less driving and making a video at the same time.
Old Mar 20, 2011 | 04:33 PM
Community Builder
It's a honda they will drive no matter what.
The washer fluid being on is that because you neglected to add fluid or is that another issue you're being plagued with.
It's hard to tell on the video because those yellow lights look like a CEL.
Old Mar 20, 2011 | 04:49 PM
the washer fluid light only comes on when the speedo trips out
Old Mar 20, 2011 | 05:32 PM
Community Builder
Care to give us further info. on your car, have you done anything to it recently?
Old Mar 20, 2011 | 06:09 PM
i got a couple days off comin up so im gonna try and fix everything when im free
- received new wheel speed sensor
- ordered airbag sensor
- gonna inspect vss if needed order new one
- 4 new shocks and springs
- FS: 2000 Accord :p
Old Mar 20, 2011 | 07:41 PM
AndyD's Avatar
First thing I would do is check your ground connections, as well as the battery terminals.
Old Mar 20, 2011 | 07:48 PM
ME Motorsports's Avatar
hm...
CRV05
Honda CR-V & Element
May 15, 2018 04:47 AM
keegur
Acura TSX
Jan 10, 2009 01:33 PM
c.dub
Mar 6, 2005 08:49 PM
Frankie324
Jul 14, 2004 07:48 PM
VTECVillain
Jan 6, 2002 11:40 AM
