tranny won't go into gear..ideas why ht?
(for a friend) - b16 transmission.
My Tranny is stuck in 3rd gear. It shifts only to 1st 3rd and 5th and reverse but the only gear that will actually grab is 3rd..any ideas what it could be?
Is this a new problem? Or was something done recently that could have caused said problem? A little background would help. sounds like it could be a bent linkage though
does it grind when u try to put it in 2nd and 4th? If it does its the tranny but if the shiter is loose and wobbly then either ur bolt that holds the shifter came out or the pin that holds the linkage to the tranny end is loose. my bolt fell out last week and i could only shift to 2nd and 3rd
a lil more info woulld be helpful tho
Im having the same problem with my tranny. My old one went out so I swapped in a new one but the shifter is stuck in nutral. When the car is off it ***** into every gear but once the car is on the shifter wont move and the clutch is way too loose.
So today I bleeded the clutch about 30 time pumped it and its a lil better but still loose. I put my car up on stands turned it on and pretended as if I was driving. Gears are a bit hard but shifts gears 1-5 + r fine but as soon as I lower the car to drive it the shifter gets super hard again.. Never happen with any of my cars before :-/
-This is what i got, 1st and 3rd and 5th goes as in the shifter when the car is off.... but when my car turns on i put it in first it has no response.... but if i put it in third it runs and is stuck in there even when i try to shift to 2nd,4th or 5th it wont go... im assuming itss my pilot bearing but i wont figure it out until i rip it out of the car,
clutch is fine since it still activates and deactivates the gears when i press and hold in the clutch.
shiftlinkage is fine cuz it was shifting perfect the 3 weeks before since i had it
OK. I COULDN'T FING A THREAD FOR MY PROBLEM SO I NEEDED TO ADD IT HERE... MY FRIEND HAS A 1990 ACURA LEGEND V6. 5-SPEED. SHE JUST HAD HER CLUTCH REPLACED AT A SHOP AND THE CAR DROVE FROM OAKLAND, CA TO SACRAMENTO, CA. IT WORKED GREAT FOR 2 WEEKS AND THEN SUDDENLY STOPPED GOING INTO GEAR. IT WON'T GO INTO ANY GEAR WHETHER THE CAR IS ON OR OFF. DOES ANYONE HAVE A CLUE BECAUSE I SURE DON'T... I CAN BE REACHED AT (530) 415-8717
BULL3TPR00F
Feb 14, 2012 10:00 PM
bowdown201
Jan 8, 2009 10:19 AM
Khmerican
Aug 30, 2007 07:16 PM
