2000 hondaaacord remote and keyless enty help
hello i recently installed my first remote stat and keyless entry on honda accord 2000 lx. i got everything to work, but when i unlock the door i ge fire from th module or the remote start bu it doesnt unlock door. but when i lock it, it will lock. the remote starter is a rs 1200 bulldog. what could be the problem? and have the wire connecte correctly i may thin. on the passenger side fuse box it says orange wire and black/blue wire. does it have something to do with factory alrmthat will cause it not to unlock? it does get firethough but the door know thats suppose to unlok wil not.pleas help.
hello, i recently hooked up a remote starter. the bulldog rs 1200. thing is i got everthing to work. when i go to unlock the door, it triggers the alarm. and i have to use my key to shut the alarm off. they say im suppose to hook the factory alarm shut down(FASD) WIRE up to the, "on the LX Model the wire is located at the KEYLESS/SECURITY Module attached to the DRIVERS UNDERDASH PANEL. " this wire is suppose to be blue. but i just cant locate it. i seen three blue wire down there. a blue/black wire,blue/white wire,and a babyblue wire. so im confused. which or where am i suppose to locate wire.?
btrotter
Nov 21, 2016 04:14 AM
