help with car alarm
Old Nov 30, 2007 | 01:44 PM
maxi15's Avatar
Default help with car alarm
I just finished installing my alarm system on my 94 accord, everything is fine except, maybe its not part of the system but when I arm my system, and I open a door from the outside without unlocking it the alarm doesnt go off.....isn't it suppose to trigger the alarm???What connection did i mess up on???
Old Nov 30, 2007 | 03:27 PM
B18C_EJ8's Avatar
You haven't tapped into the proper door trigger wire...
Old Nov 30, 2007 | 04:29 PM
maxi15's Avatar
Default Re: (B18C_EJ8)
i checked with my multimeter and when I open the door i get a negative charge on the wire I hooked it up 2 and I believe that's what it's suppose to do
Old Dec 1, 2007 | 12:26 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: help with car alarm (maxi15)
what kind of alarm?
Old Dec 1, 2007 | 01:05 PM
SaLvAcIvIc97's Avatar
Default Re: help with car alarm (wrx-killer-Sti-eater)
YOU PROBABLY HOOKED IT UP TO THE WRONG WIRE ON THE ALARM BRAIN. FOR NEGATIVE DOOR TRIGGERS WHICH YOUR ACCORD IS YOU NEED TO USE THE GREEN WIRE FROM THE ALARM BRAIN TO HOOK UP TO THE DOOR TRIGGERS. BUT THIS APPLIES TO VIPER AND PYTHON ALARMS......
Old Dec 1, 2007 | 03:36 PM
fcm's Avatar
fcm
Old Fart
Default Re: help with car alarm (SaLvAcIvIc97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SaLvAcIvIc97 &raquo;</TD></TR><TR><TD CLASS="quote">YOU PROBABLY HOOKED IT UP TO THE WRONG WIRE ON THE ALARM BRAIN. FOR NEGATIVE DOOR TRIGGERS WHICH YOUR ACCORD IS YOU NEED TO USE THE GREEN WIRE FROM THE ALARM BRAIN TO HOOK UP TO THE DOOR TRIGGERS. BUT THIS APPLIES TO VIPER AND PYTHON ALARMS......</TD></TR></TABLE> Stop yelling, we can hear you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxi15 &raquo;</TD></TR><TR><TD CLASS="quote">I just finished installing my alarm system on my 94 accord, everything is fine except, maybe its not part of the system but when I arm my system, and I open a door from the outside without unlocking it the alarm doesnt go off.....isn't it suppose to trigger the alarm???What connection did i mess up on???</TD></TR></TABLE> Make and model of alarm???
How long are you waiting after arming before you open the door?
Does your Accord have a delayed dome light, [stays on for a bit after you close the door]? 94
Old Dec 1, 2007 | 05:13 PM
maxi15's Avatar
It's working I tink it was because I was opening the door too soon thankyou everyone for your post. :D
The GreenD16
Feb 4, 2012 04:47 PM
Rthom21
May 26, 2008 08:14 PM
blue_hatch
Audio / Security / Video
Feb 24, 2008 08:13 AM
JK_Motorsports
13
Jul 12, 2007 12:28 PM
djbrandonr
Jul 22, 2006 01:25 PM
