da brake conversion on ef
front and rear complete knuckle and trailing arm...if its a crx your doing it on..then you will need the crx si ebrake cable. da brake booster and master cylinder would also be a recommended choose.
If you change the master or the booster to DA you must change both or they will not match. Also the ABS/non ABS masters and boosters match. Best to get both parts from the same car.
pnapolitano29
Nov 26, 2014 08:58 PM
juanito297
Nov 26, 2008 11:09 AM
88SeeOurEx
11
Oct 28, 2008 02:13 PM
B16Jacques
May 6, 2005 12:43 PM
