da brake conversion on ef
to do the front and rear brakes what all do you need other then the 40/40 proportioning valve do you need the booster also?
Re: da brake conversion on ef
front and rear complete knuckle and trailing arm...if its a crx your doing it on..then you will need the crx si ebrake cable. da brake booster and master cylinder would also be a recommended choose.
If you change the master or the booster to DA you must change both or they will not match. Also the ABS/non ABS masters and boosters match. Best to get both parts from the same car.
pnapolitano29
11-26-2014 08:58 PM
juanito297
11-26-2008 11:09 AM
B16Jacques
05-06-2005 12:43 PM
