need a spring compressor to replace stock ITR springs?
Old Mar 18, 2011 | 08:34 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default need a spring compressor to replace stock ITR springs?
You definitely dont need one for the rear springs...to remove them from the shock or reinstall them.
But what about the fronts? I don't care about dissasembly. I never use a spring compressor for that. I just remove the top nut while the shock is still in the wheel well with the strut mount still bolted to the tower.
Do you need a compressor to push the spring/top mount past the shock theads? Or is it already pretty much past the threads like in the rear.
Old Mar 18, 2011 | 08:37 AM
thundernoodle's Avatar
Default Re: need a spring compressor to replace stock ITR springs?
I did....
Old Mar 18, 2011 | 09:23 AM
Dave-ROR's Avatar
No.
Two people have one push on top mount and other person puts the nut on a few threads or you can install it in pieces and jack the lca up to get the enough threads to put the nut on.
Old Mar 19, 2011 | 04:01 PM
B serious's Avatar
Cool thanks. I usually use the jack under the LCA method on rears. I don't remember if I've done it on the fronts.
Toolman
Suspension & Brakes
May 2, 2005 06:30 AM
StolenTeg
Mar 24, 2004 04:41 PM
HondaCivicEx98
21
Apr 15, 2003 12:13 PM
thenick
Mar 19, 2002 06:47 PM
Ignitecivic
Mar 17, 2002 04:37 PM
