Coating recommendations - pistons, turbine housings, exhaust parts, etc.
Old Mar 18, 2011 | 06:46 AM
HybridKOOP's Avatar
Icon7 Coating recommendations - pistons, turbine housings, exhaust parts, etc.
Hey guys,
I tried searching but the HT search engine makes me want to break things. With that aside...
Does anyone have a good recommendation of where I can send multiple parts to be coated? I'm a big fan of coating, but haven't really found one place that does it all. Looking for piston skirts to be done, domes, turbine housings, some exhaust parts, manifolds, etc. Looking for most likely a black satin finish or something similar to FULL-RACE's HPC Hiper coating. Any advice is appreciated.
Lou
Old Mar 18, 2011 | 06:59 AM
Turbo-charged's Avatar
Default Re: Coating recommendations - pistons, turbine housings, exhaust parts, etc.
james at IPG does great work on the exhaust components - not totally sure if he does pistons etc or not though, never asked.
Old Mar 18, 2011 | 07:06 AM
s2kfromhell's Avatar
Pretty-n-Pink
I can vouch for james as well, he did my s2k stuff.
Old Mar 18, 2011 | 07:35 AM
HybridKOOP's Avatar
Wow, funny that I grew up in FL with James and didn't know this.
Mr. Innes, hit me up.
Everyone else, keep the suggestions coming in case IPG's stuff isn't high temp enough for turbine housings, etc.
Lou
Old Mar 18, 2011 | 07:39 AM
Pretty-n-Pink
ipgcoatings.com
Old Mar 18, 2011 | 07:40 AM
HybridKOOP's Avatar
Thanks man.
Old Mar 18, 2011 | 08:07 AM
cibao2ner's Avatar
ipg and swaintech.com are the only 2 you need to know about....and you can coat your combustion chamber..exhaust port and header in and out.....heat = power so if you keep the heat inside then...in theory it should spool the turbo faster...also you can do your turbine housing and downpipe.....then piston skirts...valve heads with combustion chamber...bearings...heat disipatating coating on intake manifold......
Old Mar 18, 2011 | 08:39 AM
legomytego's Avatar
And this guy he knos his **** you wanna see more of his work get on evom or his Facebook page http://www.tiradocustomcoatings.com/
Old Mar 18, 2011 | 09:30 AM
sohc95vtec-t's Avatar
James at IPG can do it all
Old Mar 18, 2011 | 10:47 AM
HybridKOOP's Avatar
Yup, just spoke to my old friend James Innes on the phone and will be sending all my stuff to him. Thanks everyone.
Lou
Old Mar 19, 2011 | 03:31 PM
Uncle Dave's Avatar
James@IPG is an brillant guy to do business with.
Old Mar 19, 2011 | 04:46 PM
josh green's Avatar
I had IPG do the tops of my pistons, looked good. He is a great guy to work with, I will probably hit him up for some exhaust coating soon.
Old Mar 20, 2011 | 01:21 PM
Enzo-Racing's Avatar
I've had great results from Swaintech
Old Mar 20, 2011 | 01:25 PM
xsi-t's Avatar
Ipg all the way we had pistons done before also James does a great job.
evokidvii
Apr 23, 2012 04:55 PM
ben987
Nov 15, 2008 08:22 AM
^RaCk^
Oct 11, 2005 10:42 PM
Nikoli
Honda Motorcycles
Jul 28, 2004 05:47 PM
