92 teg ls fuel pump issue please help!!!!!!!
Old Mar 16, 2011 | 07:02 PM
ghettoda9's Avatar
Icon3 92 teg ls fuel pump issue please help!!!!!!!
I have a 92 integra ls this car has had a problem with the fuel pump. the car wont prime the pump sometimes. then other times it will prime and work perfectly. and then sometimes like today it will shut off the pump, car stalls and wont prime the pump when i try to start it. ive tried everything i could think of but its still giving me a hard time. ive changed the relay. twice. new fuel pump (tested it) and new fuel filter. could it be a bad connection? if so can somebody show me where it could be? my ecu and wires leading to it are all fine, no signs of corrosion. could it be the wire harness for the pump on top of the tank?
Old Mar 16, 2011 | 07:28 PM
KtHaNxBai's Avatar
Default Re: 92 teg ls fuel pump issue please help!!!!!!!
check if the main relay is ok, other than that, u need to change that pump..its really old..i changed mines not to long ago..its a pita, but worth all the headaches
Old Mar 16, 2011 | 07:32 PM
djkobe's Avatar
if its a new fuel pump as you stated as well as new relays then i could get out the old multimeter and check how much power you have flowing to the pump and make sure its the correct voltage
Old Mar 16, 2011 | 07:33 PM
ghettoda9's Avatar
Icon3 Re: 92 teg ls fuel pump issue please help!!!!!!!
well the pump is fine i just changed it a week ago and i tested it. the main relay is new too so i dont think that could be it either. i cant think of what it could be
Old Mar 16, 2011 | 07:37 PM
ghettoda9's Avatar
could the wrong voltage cause my pump to shut off while driving and prevent it from priming?
Old Mar 16, 2011 | 10:43 PM
djkobe's Avatar
im no expert but the wrong voltage could easily cause for problems such as these. i believe the correct voltage is 6-7v but someone please correct me if im wrong, if it is not receiving the correct voltage then it would have trouble priming and staying on.
Old Mar 17, 2011 | 06:05 AM
MD426's Avatar
Sounds like a power or ground wire is loose. Make sure the connections to the top of the fuel pump is good as well as down the line towards the fuse box.
Old Mar 17, 2011 | 06:20 AM
fcm's Avatar
fcm
Old Fart
Voltage at pump should be 12V+.
I would check fuel pump ground, PGM-FI Main Relay ground and the 3 powers for the PGM-FI Main Relay, also check ECU/ECM control lead, [green/black] to the PGM-FI Main Relay, [fuel pump relays coil] the ECU/ECM supplies a ground.
Easiest way to test if it is an ECU/ECM problem is to use a jumper lead to supply a ground to the green/black lead/terminal at the PGM-FI Main Relay when pump will not prime.
If the above works, pump runs with "jumper" ground, the problem is the ECU/ECM. you will need to test the IGP1 and 2 inputs to the ECU/ECM, yellow/black, both must have 12V+ on them when ign. switch is in run or start. 94
Old Mar 17, 2011 | 09:17 AM
djkobe's Avatar
i was looking all through my manual and the only numbers i found were 6-7 but that did sound a little low, listen to what fcm said..hah
Old Mar 17, 2011 | 11:32 AM
ghettoda9's Avatar
i think my ecu is bad... i took it out and it smelled really wierd. i'll check voltage on the connections tho. but what are signs of a bad ecu? ive heard a bad ecu can stop the pump while its on and can cause it not to prime
Old Mar 17, 2011 | 12:43 PM
fcm's Avatar
fcm
Old Fart
The ECU/ECM is what controls the fuel pump relay, re: my last post.
Try the ground like I suggested, if pump primes when you supply a ground to the green/black lead atthe PGM-FI Main RElay. 94
Old Mar 25, 2011 | 12:49 PM
ghettoda9's Avatar
well i think it is a bad connection somewhere in front. my car wouldnt prime the pump and the cel was on. then i was moving the main relay to see if i felt it click, i touched some cables and the cel blinked off and back on. seems like a wire might be loose or maybe cut. sometimes the relay makes a hiss or whirring noises like its getting too much power, which makes me think its the connections. im gonna check all the wiring and clean connections to the fuse box. the car has an aftermarket alarm on it, can i just remove the connections to it and patch up the wires or should i leave it alone? oh and does anyone know where the ground is to the ecu and main relay?
logjammin
17
Jul 29, 2013 07:59 AM
Chris del sol
Apr 16, 2013 10:42 PM
zippakilla
Feb 6, 2009 04:01 AM
huge230
Jun 19, 2007 02:58 PM
