battery or alternator????
Old Sep 26, 2002 | 06:41 PM
wizzards581's Avatar
Default battery or alternator????
while driving.. my charge lite is on... at nite i went racing and while driving bac home i notice all my gauges are dead... my clock is dimming and.... i realize the lites are goin out... i thot the car died but it didnt... it ran normally... so i wouldnt know if its the alternator or the batterY?? my car didnt start after it was shut off but i made it home safely in the dark... the next morning it started back up normally but charge lite is back on.... wat is it?
Old Sep 26, 2002 | 06:46 PM
Kamin's Avatar
Default Re: battery or alternator???? (wizzards581)
go take the battery to any local shop (autozone, checker)
they will check it for free.
Old Sep 26, 2002 | 06:47 PM
shawnhayes's Avatar
Probably the alternator, but it could be the voltage regulator. The battery is very unlikely to cause the light ammeter to go on (although not impossible). Get it fixed ASAP, or it will leave you stranded.
Probably on a dark road in a place you don't wanna be.
Good luck.
Shawn
Old Sep 26, 2002 | 07:08 PM
Default Re: battery or alternator???? (KAMiN)
its been to autozone... puts out 12 volts.. so does my dmm says also...
but what im asking is which should i fix first?? alternator or the battery?? but wat are those little magnet thingy in the alternator call?
Old Sep 26, 2002 | 07:19 PM
SpoonFedHatch's Avatar
well, if the batt's putting out 12 volts and HOLDING that charge, it's probably your alternator, BUT, first, check ALL electrical connections and make sure nothing's loose or rubbing, and if everything looks clean, it's your alternator.....it's not even worth rebuilding a honda alternator, so just go to pepboys/autozone and get a reman'd one w/ lifetime warranty and you'll be fine....late
Old Sep 26, 2002 | 07:45 PM
ryu12341's Avatar
Default Re: battery or alternator???? (SpoonFedHatch)
you talking about the brushes I assume. Check your alternator fuse! $2.15 saved me a whole bunch of worrying. I'd check there first. Then take an ohm meter and check the voltage your alternator is putting out, or just take to Napa.
Evan
Old Sep 26, 2002 | 08:31 PM
bryant's Avatar
Default Re: battery or alternator???? (ryu12341)
Same thing happen on my old accord. replaced alternator and no more problems. Easy fix.
obuhmyuh
May 28, 2008 03:27 PM
gascrazy
Sep 17, 2007 06:05 PM
IHTFP
Jul 30, 2006 07:01 PM
Fatty_1775
Oct 23, 2002 02:33 AM
Martaigne
Jul 14, 2002 04:19 PM
