idles at 3k help!!
Make sure the idle screw is tightened all the way they come loose very easy just use a flathead screwdriver its on the throttlebody. if thats all the way tight unplug the iacv on the back of the intake manifold while the car is running if u unplug it and ur car is still running you have a vaccum leak. Hope this helps pm me if u have any questions
options you got your idle screw is really loose
2.vaccum leak somewere in your lines or the manifold
3 your temp sensor is unplug or its bad
pm me if any questions bro but it should be an easy fix
headhunter
Aug 18, 2003 08:14 PM
