d15b vtec
Old Mar 15, 2011 | 03:47 PM
7thheaven's Avatar
Default d15b vtec
I want a straight answer and no bullShhh about other stuff. What do I have to do to run this stuff (nitropropane) (yes its a liquid) on a stock d15b. Do I need bigger injectors or anything? Read this article before you post. You might find it intresting.
http://www.hotrod.com/techarticles/n...ive/index.html
What needs to be done to run this stuff?
Old Mar 15, 2011 | 05:12 PM
jdmboyef9's Avatar
Default Re: d15b vtec
You should post in the Hybrid section. Most of the people here have no idea what you are talking about. Aside from that you will likely need the same components required to run E85
Widewand o2
Lambda Gauge
bigger fuel pump
bigger injectors
Engine managment such as Hondata S300 or Chrome
Without full tuning this will lean out your engine causing severe detonation. At $30 a gallon, fully tuned on a D15B you might get 5 extra horsepower....The article claims 20hp on V8's. Might be a good idea for a built turbo or N/A motor but it's not as good as NOS.
Old Mar 19, 2011 | 08:02 AM
7thheaven's Avatar
you pretty much answered my question =D
yea I have no intention of ever doing that. I was just curious what would have needed to be done inorder to use nitropropane.
Old Mar 19, 2011 | 01:14 PM
slywfbpsi's Avatar
If you never had an intention of even trying it, then why post it? You could of just as easily made an account on that site and asked them.
Old Mar 19, 2011 | 04:28 PM
JamesOun's Avatar
I need some HELP out there? I have a automatic 95' Honda Civic Ex with a D15B engine that I had a friend to swap it for me. Cause the original engine is a D16Z6 had a rod knock and was running with a P06 E.C.U.
Well my question is, What kind of E.C.U should I us on a Automatic D15B engine? Cause some people told me to use a P28 E.C.U which it didn't work now I have a P75 E.C.U is that ok to use on this kind of engine?
Old Mar 20, 2011 | 05:04 AM
slywfbpsi's Avatar
Then make your own post.
Old Mar 21, 2011 | 12:48 PM
7thheaven's Avatar
to: slywfbpsi... Intention or not Idc. As I stated I dont want no BS from anyone. I choose to come here and post so if u got a problem with that u can just simply click the back button.
To the dude who tried to use the p28 ECU. Are you OBD 1? I have a friend that has a d15b with the P06 ECU and he is OBD 0... for him to use the p28 he needs to convert. Idk im just letting u know what I know. I dont really know too much about that stuff.. yet.
Old Mar 21, 2011 | 12:51 PM
d16efsedan's Avatar
i dont think he is obd0 with a p06 ecu since that is a obd1 ecu!!
Old Mar 21, 2011 | 01:36 PM
slywfbpsi's Avatar
If you chose to come here and post, then you will just have to accept that people will reply back with what they want to post as well.
david1787
Apr 18, 2016 01:28 PM
thatcivic96
13
Jan 30, 2010 04:27 PM
mortificationrock
Aug 10, 2008 11:31 AM
Pay2play killa
Oct 20, 2006 09:27 AM
99b18
Mar 18, 2004 05:21 PM
