hazards & signals don't work! please help
so i did alot of searching and didnt find much, but from what i could gather up, people are pointing towards the flasher relay. ive looked but couldnt find where the location of it is on diagrams. can someone point me in the right direction please!!! thanks in advance!
its for a 5th gen btw
they quit working at the same time?
what was the last thing you did to it? i would start there. if nothing has been done, check your wiring. i'm not positive, but i think the flashers and turn signals are on different circuits.
Have you checked your fuse? Use a test light and test it if you haven't already.
Also, if the hazard light switch is not plugged in then neither will work.
Yep, check fuse first. If it's good then it's probably the relay. It's in the under-dash fuse panel, near the top in the center; it's black iirc and pretty wide (horizontal orientation).
k20eklipse
26
Jul 12, 2010 08:55 PM
