CEL during wot.
Old Mar 14, 2011 | 07:40 PM
Brockasaurus's Avatar
Default CEL during wot.
my check engine lights comes on some times when i am just cruising then give it full throttle nothing happens, it runs perfect. but when i turn it off then turn it back on to check the code it goes away. any one have this problem.. this is in a 93 del sol si with a d16z6.
Old Mar 14, 2011 | 07:51 PM
Former User's Avatar
Default Re: CEL during wot.
You can recover the code if, when the CEL lights, you leave the engine running while you jump the service connector.
Old Mar 14, 2011 | 08:05 PM
DelsolVted's Avatar
mine did the same thing and it was a my vtec pressure switch. cel dont come on no more now! James. Code 22 was my code
Old Mar 14, 2011 | 11:34 PM
b5bellyscraper's Avatar
I had the same issue in my del sol about a year before I got rid of it. Pressure switch probably like he^^ said. Also had this problem with a v6 Odyssey I worked on a couple months ago
delslomt
Dec 28, 2012 01:03 PM
jwagner
Engine Management and Tuning
Apr 8, 2012 07:38 PM
HOUSTONtx
Jul 10, 2008 01:02 PM
prophecy7115
Mar 17, 2008 08:40 AM
