right front lower a-arm doesn't fit
Old Mar 14, 2011 | 10:22 AM
pliskin8's Avatar
Icon2 right front lower a-arm doesn't fit
i'm trying to install a front sway bar into my ej6, the sway bar is off an 94 grs and the front lower a-arms are off an ej8, but the right one just doesn't lign up the left one does with no problem, i took them off an ej8 at the junk yard that still had the sway bar mounted so i cant figure out why it wont fit in my car, the number stamped on it the Right one is RAFF35 P33 and the left one is LAFF20 L14, do i have the right part??
in the pic the one on top is the right one and as you can see that little bend on top is what doesn't allow it to lign up to the car
Old Mar 14, 2011 | 11:06 AM
instructor74's Avatar
Default Re: right front lower a-arm doesn't fit
My first guess looking at that arm is that it is bent esp since you had the other one bolt up fine. Funny thing some times you get bent parts from a junk yard
Old Mar 14, 2011 | 11:11 AM
pliskin8's Avatar
that was my first guess but the car i took it off from was crashed from the rear but?? i guess i'm gonns have to get a different one
eg7
52
Jan 28, 2011 05:02 PM
patrickstar
Feb 24, 2009 10:07 PM
RACEPAK
Dec 18, 2005 10:32 AM
{Powered by VIII}
Jul 19, 2004 05:50 PM
AThiker
10
Nov 25, 2002 03:32 AM
