how to paint a valve cover useing single stage paint
Old Mar 14, 2011 | 09:54 AM
Fresh Crx's Avatar
Default how to paint a valve cover useing single stage paint
my friends is painting his valve cover and wants to use single stage paint how to you use it and at what do you use in order for the paint not to chip off when it get real hot on the engine since he is using paint and not the high temp colors from the can. and what psi would you use on a gravity gun to do this
Old Mar 14, 2011 | 10:03 AM
Hawkze_2.3's Avatar
Default Re: how to paint a valve cover useing single stage paint
You don't need high temp paint for a valve cover. Those high-temp paints from a can are much worse than real automotive paint.
Prep is the same as you would do for anything else; the surface must be CLEAN and sanded/de-glossed.
Old Mar 14, 2011 | 10:15 AM
Fresh Crx's Avatar
So after we clean and prep it just paint it and clear it with clear and when it gets hot on the motor it won't chip
Old Mar 14, 2011 | 01:42 PM
Hawkze_2.3's Avatar
Anything will chip if you hit it with a screwdriver.
Old Mar 14, 2011 | 02:19 PM
Fresh Crx's Avatar
After I clear it with clear not With a can spray but with my gravity gun will it chip from the heat from the engine
Old Mar 15, 2011 | 06:27 AM
Hawkze_2.3's Avatar
Chipping is caused by poor adhesion due to poor prep work, so if you prep it right it will not chip. Again, engine heat does not seem to affect automotive paint....I did a test spot on my engine block right below the header a few years back and it has been fine.
Old Mar 21, 2011 | 09:33 AM
jdmcrx_echelon's Avatar
You also said you were gona shoot it with single stage.... then in another post you mentiond color then clear. Single stage is exactly what it says... the paint dries to a gloss so you dont clear it. Unless you meant base coat/clear coat and not single stage. Your final product will only be as good as the prep work you put into it.
Old Mar 27, 2011 | 06:15 PM
Umoan4thebone's Avatar
completely agree.. prepping is the most critical part of the paint process
snakecbaker
Jun 8, 2012 09:14 AM
lilboxx
36
Apr 14, 2012 09:45 PM
94c1v1cex
May 20, 2007 07:11 PM
JDMTurboCivic11
Mar 6, 2005 08:09 AM
crx_ef8
May 11, 2003 01:54 PM
