Transmission & Drivetrain Gearboxes, Differentials, Clutches
Clutch release arm problem..!!!
Old Mar 13, 2011 | 07:31 PM
hammoud's Avatar
Icon6 Clutch release arm problem..!!!
Hi
Just bought a 88 CRX on the weekend.
The person i bought it off somehow snapped the nut that adjusts the clutch cable. I had a spare one sitting around from a CRX that i had a year ago so i installed it.
Now the problem im having is, when i push in the clutch pedal the clutch release arm stays all the way in. It's almost as if the arm doesn't retract, just stays in when i push the pedal..
So now i can't drive the car because the clutch is constantly on untill i manually (with my hands) return the clutch release arm to where its supposed to be..
I know its not the clutch cable because i made sure that theres play in it and i know it wasn't holding the release arm in because the clutch pedal is very loose..
I think the clutch may need replacing or it's been fitted wrong. But not too sure though..
Any ideas would be great.
Thanks
Old May 3, 2011 | 10:03 PM
ALLDAWAY's Avatar
Default Re: Clutch release arm problem..!!!
going through the same thing on my 92 integra. ive come to the conclusion that there is a broken spring that returns the release bearing arm thing inside the trans . in other words u gotta pull the tranny off .
Old May 4, 2011 | 02:39 AM
91_Civic_hybrid's Avatar
I had the same on my 91 hatch. One of the ears on the bearing broke so the it was binding up when releasing the clutch
Haarstad
Jun 24, 2012 09:50 PM
orangeskater
Sep 21, 2008 09:57 AM
jeffruby
Apr 16, 2006 11:48 PM
renes
Nov 21, 2005 11:25 AM
spaceman
Sep 24, 2003 11:24 AM
