quick question about welding..
Old Mar 13, 2011 | 04:56 PM
jdmISmyGOD's Avatar
Default quick question about welding..
hey, i got a quick question to ask...wanna make a double sure about this, if im going to weld up the radiator support on the chassis...so am i suppose to do the 1/30 and right now, i got no argon at all n its hobart 140amg so its good one...is 1/30 good enuff or its too much to burn thru the metal sheet? pls lmk, thanks....
Old Mar 14, 2011 | 10:33 AM
SovXietday's Avatar
Default Re: quick question about welding..
...sigh.
Why can't people do things the right way for once? Get freaking shielding gas, and while you're at it at least clean off the paint from both surfaces before you weld it.
As for melting the sheet metal, depends how you set up the MIG to weld and how good you are.
Old Mar 14, 2011 | 10:46 AM
jdmISmyGOD's Avatar
I know, lol but I tho without gas will be okay too but it's not so I will try get the argon when I have enough money but sucks is that I got no cart, lol
Old Mar 14, 2011 | 11:10 AM
SovXietday's Avatar
Just get a small bottle, they're not that expensive and easily portable. They're maybe a foot and a half high, it's what I have for my MIG and the MIG is heavier. Also, I believe MIG uses a 3 gas mix, but whoever you're picking gas up from should know for sure.
Clean metal with a shielding gas will weld nicely, no shielding gas is going to weld like **** and frustrate you. I promise.
Old Mar 14, 2011 | 11:17 AM
jdmISmyGOD's Avatar
Thanks, man appreicate that and will try get one once I get sand for my blaster to remove all rusts under the skirts n it's really horrible, lol.
Old Mar 14, 2011 | 11:19 AM
SovXietday's Avatar
No prob man, good luck and have fun.
Old Mar 14, 2011 | 12:52 PM
civicgsrturbo32's Avatar
If your welding just mild steel 75/25 agron co2 mix is what you want. I paid bout 200 bucks for my 80cf bottle and that was filled so bout $170 for the bottle.
Old Mar 15, 2011 | 04:49 PM
black0hatch's Avatar
you could do it fluxed core without gas ive done it. but like eveyone says the gas helps out alot.
Old Mar 18, 2011 | 10:43 AM
jdmISmyGOD's Avatar
yeah, i will like to have that bottle so i can weld it lookin nicely, u know..not mess it up n do it all over, ugh..hate when it go thru the sheet..
twkdCD595
Welding / Fabrication
10
Dec 19, 2010 07:48 AM
juiced2ndgenteg
Jan 31, 2010 04:20 AM
Flashmn
Dec 26, 2006 07:29 AM
HybridHatch
May 11, 2005 09:32 PM
Jonathan_ED3
Apr 14, 2003 05:13 PM
