Help need on Momo Horns!!
Old Sep 26, 2002 | 03:27 PM
Tiwe's Avatar
Default Help need on Momo Horns!!
how do u guys make ur horn work on ur momo steering wheels?
i bought the Mellinum steering wheel and the momo hub
but under the hub there is this 3 metal pushers/retractable bits and its supposed to be touching some metal surface of some sort but there is no metal surface after u remove the stock steering wheel on ITR....is there another way around it....please help thanks
Old Sep 26, 2002 | 04:24 PM
Type Goch's Avatar
New User
Default Re: Help need on Momo Horns!! (Tiwe)
Attention Koy,Yoshi or whoever does a search, please report to this thread. Thank you.
Old Sep 27, 2002 | 04:05 PM
Tiwe's Avatar
Default Re: Help need on Momo Horns!! (Type Goch)
ok i did a search and the explaination want clear enough ....please help thanks
Old Sep 27, 2002 | 04:11 PM
yoshi234's Avatar
I shoot brides
j00 try this thread?
Old Sep 27, 2002 | 04:46 PM
Tiwe's Avatar
Default Re: Help need on Momo Horns!! (yoshi234)
It's easy.
There is black plug that goes into the cable reel. that is your horn wire.
Take wire need to wipe the copper ring on the back of your hub. Make a bracket so that something wipes that copper ring. then attach that wire to whatever is wiping the bracket.
Then wire up your horn following the instructions. Basically one to the lead from the copper ring and the other to a ground (ie the HUB or steering wheel).
Beep Beep, horn works.
PLEASE DONT MAKE ME TAKE OFF MY STEERING WHEEL TO SHOW YOU!!!!!
ok whats ground? basically i still dont understand...i got my steering wheel bolted on now but i dont have horn.
Old Sep 28, 2002 | 08:40 AM
Tiwe's Avatar
*bump*
bigBOI_92DA9
Dec 8, 2005 09:26 PM
sramDcivicEK
Jan 25, 2004 06:39 AM
714eg
Jul 20, 2003 08:36 PM
Hard2Find
14
Jul 10, 2002 01:16 PM
lsvtec42
Feb 4, 2002 09:20 AM
