help/horn doesnt work!
Old Dec 8, 2005 | 06:38 PM
bigBOI_92DA9's Avatar
Default help/horn doesnt work!
Just bought a sparco steering wheel and hub. After installing them the horn would work. So if anyone can please help me with this please!
Old Dec 8, 2005 | 07:04 PM
Tientruong's Avatar
does it click when u press the horn button/
Old Dec 8, 2005 | 07:31 PM
SlammedDC2teg's Avatar
Default Re: help/horn doesnt work! (bigBOI_92DA9)
what car is it for? Because if it had an airbag, you horn will never work unless you rig it up
Old Dec 8, 2005 | 07:41 PM
53JDMDC2's Avatar
horn wont work. you need to find the plug/wire that goes to the hornand have to rig somthing up so the wire contacts the copper ring on the back of the hub.
had same prob with my horn. found a thick sheet of copper and cut a piece out bent it up so it reach from a screw hole. put a eye terminal on the wire and also attached it to the screw hole so it would contact the copper piece i made.
Old Dec 8, 2005 | 09:26 PM
Default Re: help/horn doesnt work! (SlammedDC2teg)
its for a DA, well let me decribe the steering wheel hub. The hub came with a four wire it has red black and yellow with green which i believe it was for the horn, and theres this last wire. other than the yellow and green which is screwed in the hub there was the 3 wires that has that copper end that hits the metal part from the steering column, since im not using the cruise control anymore, I took the other 3 wires, was that the right way or should i left those wire in there?
98GeeYes-Are
10
May 6, 2004 11:36 PM
sramDcivicEK
Jan 25, 2004 06:39 AM
714eg
Jul 20, 2003 08:36 PM
AllMotorITR
Aug 19, 2002 01:38 PM
lsvtec42
Feb 4, 2002 09:20 AM
