Gas light does not work when low on fuel.
how low is it? I thought mines didn't work so I put it to the test and after like 1000 miles it finally came on...... i have a 96 but I'm sure its the same, also had a del sol and it was the same way
It's only 3 components, low fuel/fuel level sender(in the tank) 1 wire running from there to the cluster and the cluster light. There is a test procedure for the sender in the FSM. On 92-95 you need to jumper pin 1-3 at the sender to check the cluster light and wiring to the cluster, and seeing as the sender is the same P/N as 96-98 Sedan, I would assume the test is the same.
First step would be to check the bulb just to make sure that its not a easy fix, if the bulb is good then check the low fuel sender like Tlarimer suggested.
egvtec
13
May 15, 2010 12:13 AM
snouka
May 17, 2005 09:04 AM
