Crank pulley removal tricks
Timing belt change in a CR-V with B20Z: Does anyone know how to remove the crank pulley without Hondas $80.00 hex tool? (Not the spanner tool used on the early D15's)
Thanks!
Thanks!
You really should use the tool (or make one of your own if you have access to a welder). I believe Amazon has one for around $20.
$25, but worth it. You'll also need a couple of big breaker bars
djnikko
19
Apr 24, 2005 07:43 PM
