Starter diagram for delsol
Old Mar 10, 2011 | 04:19 PM
prime-R's Avatar
Default Starter diagram for delsol
Ok so i was changing the ignition swith i decided to change the starter layout.the previous owner had the starter wired direct to the ignition swith so im looking for a diagram to put it back to normal,ive searched but nothing.thanks guys
Old Mar 10, 2011 | 04:44 PM
Linked's Avatar
Default Re: Starter diagram for delsol
i dont know how to get pics up of my diagram but i can help a bit with you:
to start with the S terminal (blk/wht wire)
-turns to a blk/red wire and goes to terminal 87 of the starter cut relay
-terminal 30 of the starter cut relay has a blk/wht wire going to the ignition switch
-terminal 85 of the starter cut relay splices into the same wire for terminal 30
-terminal 86 has a blu/blk wire going to the clutch interlock switch
Old Mar 10, 2011 | 07:01 PM
prime-R's Avatar
ok so here is a pic,if you see on the starter where there is a red wire taped to a wire on the starter.What i want to know what that wire originally goes to so i can rewire it back to stock.
Old Mar 11, 2011 | 11:38 AM
prime-R's Avatar
Bump anyone
billyhoe
Dec 21, 2020 11:52 AM
tUnz_on
27
Oct 19, 2011 03:35 PM
JDM_Apocalypse
Audio / Security / Video
13
Aug 9, 2007 01:36 PM
Stewie
Aug 14, 2004 03:44 PM
