shiftlinkage
today i took my carpet out and saw that the shiftlinkage is not bolted right it doesn't even have bolts!. the tranny was replaced not too long ago so i guess they put it back in a rush.
I dont have jack stands yet so i cant see ( from the bottom) if the bolts are different length or one is about to fall off.
My quaestions are:
1. when i order a shiftlinkage fomr honda would it come with bolts and bushings ?
2. could this be the reason why sometimes is hard to go into reverse ? i also heard it could be that my short shifter is to tight.
thanks for your help in advance
My quaestions are:
I know, that's what I'm referring to. You can add nuts on them to secure them more but it should be fine the way it is. You don't need to buy a whole new shift linkage.
You can grab some new bushings for like $15.00 bucks here. http://www.heeltoeauto.com/home.php?cat=321
The shift linkage consists of 30 diff. parts, all sold separately, bushing "kits" and so on will also be available... http://acuraautomotiveparts.org/acur...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal 94
Thanks for the good info alot of stuff that I didn't know. The fact that one is longer than the other still bothers me and one is in a angle ( but i feel more safe now knowing that the nuts are welded to shell , i thought it was going to fall off while i was driving) I will try to get matching bolts from home depot as for the bushings which ones are better the ones from passwordjdm.com or those red ones ?
It looks like you are good with a camera, so why don't you take a picture of what you are going to work on before taking anything apart? It might help get it back together right the first time.
I would not replace those shifter bolts with just any grade bolt. Home Depot would not be the place to purchase automotive grade bolts.
i havent taken anything apart yet. the owner before me did i guess Im just trying to get everything right.
Good point about the bolts im going to contact the dealership first.
