What is the correct ohm for the TPS GSR TB**
The Throttle Body is for GSR and i was wondering what the correct ohms were for the TPS
i know that there is away to do it with the tps hooked up to the car and on AUX with measuring the volts/ but i would rather do it out of car for clearance reasons
i have seen the video with the skunk2 TB on youtube where he finds the ohms, but i just want an exact number that i should get at WOT and base idle
--i've done tons of searches and can only seem to find the .5v at base and 4.5v at WOT
help will be greatly appreciated!!
or if you have the car set up correctly and have an multimeter just unplug the tps plug and see what ohms you get ... with car off of course and then open throttle and tell me what ya got
