Slight tapping sound in morning on cold start up
Old Mar 10, 2011 | 09:00 AM
pityocamptes's Avatar
Default Slight tapping sound in morning on cold start up
Is this normal? Its not super loud, and its not like a rod knock or bearing going south. Its on a 1998 Honda Civic Ex with ~82K miles on it. After it warms up it seems to go away or slightly be heard, seems like its when the idle comes down (certain band width) while warming up. Runs great, so I'm not sure if this is indicative with Honda's, or ??? Thanks!
Old Mar 10, 2011 | 09:16 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Slight tapping sound in morning on cold start up
Sounds like piston slap.
Old Mar 10, 2011 | 09:51 AM
Is that common? The engine only has 85K on it!! Should I be concerned or can I expect to get another 100K or so from the engine?
Old Mar 10, 2011 | 09:55 AM
Linked's Avatar
wouldnt piston slap still be there when the engine warms up?
Old Mar 10, 2011 | 10:02 AM
I adjusted the valves and its not as loud, so maybe its something in the valve train, however it does sound lower in the block, but then again sound sometimes travels and can be deceptive...
Old Mar 10, 2011 | 10:17 AM
The Grumpiest
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/piston-slap-2145465/
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/piston-slap-rod-knock-2881641/
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/engine-ticking-when-cold-2565723/
There's more.
Old Mar 10, 2011 | 10:48 AM
HatchbackSqueegee's Avatar
Let me guess your using a Fram oil filter?
Old Mar 10, 2011 | 11:14 AM
Nope. Mobil 1 with synthetic oil...
20ls01
Jul 15, 2007 09:21 AM
islowteg
May 8, 2007 03:43 AM
movingIIshadow
May 7, 2006 04:01 PM
hondapwr
11
Nov 15, 2005 12:15 PM
satintegra
May 26, 2002 05:37 AM
