Tapping sound while engine cold
I recently noticed a tapping sound right after startup, while the engine is cold. It's most noticeable when I try to drive it right away still cold. It's a really irregular tapping sound, and doesn't have a consistent rythym.
It sounds like it's coming from the head. If it's valve tapping, does that mean my clearances are too wide, or too narrow?
Re: Tapping sound while engine cold (hondapwr)
Re: Tapping sound while engine cold (j4yd3um4lyf3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j4yd3um4lyf3 »</TD></TR><TR><TD CLASS="quote">start with adjusting the valves...
https://honda-tech.com/zerothread?id=1305086</TD></TR></TABLE>
Actually I recently adjusted them to:
Int=.17mm
Exh=.20mm
The instructions you linked are a bit different than what I did. I measured between where the rocker arm touches the camshaft on my B16.
Int=.17mm
Exh=.20mm
Imperious: Mod of Valor
Re: Tapping sound while engine cold (AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer »</TD></TR><TR><TD CLASS="quote">It could be valves or piston slap. Both of which are very common to Honda motors.
Re: (crashoveride)
Most of the info I found online related to piston slap is for GM motors.
http://www.pistonslap.com/pistonslap.wav
It doesn't sound like that. (For which I am thankful, because they have pictures of destroyed cylinder walls on the site too)
piston slap happens with forged pistons when cold, once they warm up goes away, on my 127kmile d15, i can hear a irregular ticking sound too, after slight warm up is dissapears
Re: (Mohsin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mohsin »</TD></TR><TR><TD CLASS="quote">piston slap happens with forged pistons when cold, once they warm up goes away, on my 127kmile d15, i can hear a irregular ticking sound too, after slight warm up is dissapears</TD></TR></TABLE>
i was not aware that pistons that are not forged slaped when cold... but i could be wrong
Re: (j4yd3um4lyf3)
afaik due to high silicone content, forged materials tends to expand, once fully warm you wont be able to hear it, as for my d15 i think i need to re-adjust my valves, just to clear things up pistons which are not forged should not piston slap even when cold.
Re: (Mohsin)
I rechecked my clearances and the exhaust valves on number 3 were way too tight. Hopefully that was the issue. I didn't think the SiR II B16 came with forged pistons...
pityocamptes
03-10-2011 11:14 AM
tegman85
09-27-2006 09:51 AM
ej2civic
10-02-2005 09:43 AM
