Help with sideskirt removal.
Old Mar 9, 2011 | 07:07 PM
93preludeftw's Avatar
Default Help with sideskirt removal.
Im taking the lip kit and sideskirts off my prelude and I need a little help with getting off the sideskirts. They're double sided taped or connected with some kind of adhesive. My question is "What do I use to get the sideskirts off with the adhesive?" goo gone? Or is there something else that works better?
Old Mar 9, 2011 | 07:14 PM
X01Michael's Avatar
Default Re: Help with sideskirt removal.
There held on by clips. U gotta hit it hard from the back so it slides towards the front then pull it off
Old Mar 9, 2011 | 07:46 PM
They're some dumb ricey side skirts
There's some kind of adhesive holding it on where it come up past the bottom of the door.
Old Mar 10, 2011 | 03:18 PM
Anybody??
Old Mar 10, 2011 | 04:50 PM
amanwani's Avatar
Its probably just double sided adhesive tape. You can try a heat gun and pulling harder.
Old Mar 10, 2011 | 06:47 PM
Hawkze_2.3's Avatar
They don't look too bad to me....guess I'm ricey, haha.
Try carefully using a razor blade to slice through the tape a little at a time, while soaking it with some sort of adhesive remover.
Old Mar 10, 2011 | 07:31 PM
snobordboy's Avatar
Moderator
I second a heat gun, go slow and peel them off, then work on the adhesive by itself as Hawkze described.
Old Mar 10, 2011 | 07:57 PM
Sounds easy enough. I'll post pics of the car once I take them off.
Old Mar 10, 2011 | 10:29 PM
saikou's Avatar
If they were molded, they might actually not look bad at all - you can even see the lines of the bottom part of the door flow with the ends of the side skirt.
Old Mar 14, 2011 | 07:13 PM
Here's the sides and you can see the front somewhat. The passenger side tape wasnt removed yet. It got too dark after to take a pic. I will have new ones soon with the exhaust and rims. Next will be the new exhaust and 16 inch rotas or whatever i find for a good price. Those nasty rims are 19s...lol Then the suspension and front and rear lips and sideskirts.
incurable
Jan 1, 2007 07:11 PM
Chris_R
Nov 15, 2006 01:00 PM
integraboy22
Mar 6, 2006 06:51 AM
EMJAY
Mar 4, 2006 03:50 PM
tampaSi
Sep 4, 2003 03:13 PM
