88 crx si swap d15b
Hey guys,
I'm new to the forums, was browing around the net and found you guys knew what you we're talking about. Here's what going on i have a 1988 honda crx si with a d16a6 currently in it and i just ordered a jdm d15b from tigerjapanese. I was just wondering all the materials i'm going to need i researched a bit and found what i think i need is some mounts, i know hasport makes some for the cable to hydro trany, a p28 ecu which i have and a jumper harness, just wondering all the things i need.
You can use your stock mounts and transmission. Use the clutch & flywheel off your a6.
Also use 0bd0 to obd1 jumper harness. The distributor need jumper plugs and you need a obd1 distributor. One 4 wire o2 sensor with male and female plugs. Vtec and vtec oil pressure plugs. Finally the ecu the p28. Thats about it may one or two things more.
okay guys i appreciate the help but i got the motor and it has two vtec solenoids? do i need a different ecu for this i did some research and apparantly i need a p2j ecu? how is this gonna work ?
thanks in advance
thanks in advance
http://www.tigerjapanese.com/index.p...mart&Itemid=26
this is the exact motor i purchased from them.
thanks for the answer man, i guess that cpu is the only way to get that running i was reading a bit and someone was saying they still used the p28 just didnt get the 3 stage vtec?
i had entertained that idea in my mind as well but whether or not you could run one of the solenoids on a dual solenoid vtec head with a p28 safely and effectively is unbeknownst to me.
Xemu
Oct 18, 2006 04:29 AM
