88 crx si swap d15b
88 crx si swap d15b
Hey guys,
I'm new to the forums, was browing around the net and found you guys knew what you we're talking about. Here's what going on i have a 1988 honda crx si with a d16a6 currently in it and i just ordered a jdm d15b from tigerjapanese. I was just wondering all the materials i'm going to need i researched a bit and found what i think i need is some mounts, i know hasport makes some for the cable to hydro trany, a p28 ecu which i have and a jumper harness, just wondering all the things i need.
Re: 88 crx si swap d15b
You can use your stock mounts and transmission. Use the clutch & flywheel off your a6.
Also use 0bd0 to obd1 jumper harness. The distributor need jumper plugs and you need a obd1 distributor. One 4 wire o2 sensor with male and female plugs. Vtec and vtec oil pressure plugs. Finally the ecu the p28. Thats about it may one or two things more.
okay guys i appreciate the help but i got the motor and it has two vtec solenoids? do i need a different ecu for this i did some research and apparantly i need a p2j ecu? how is this gonna work ?
thanks in advance
thanks in advance
http://www.tigerjapanese.com/index.p...mart&Itemid=26
this is the exact motor i purchased from them.
thanks for the answer man, i guess that cpu is the only way to get that running i was reading a bit and someone was saying they still used the p28 just didnt get the 3 stage vtec?
i had entertained that idea in my mind as well but whether or not you could run one of the solenoids on a dual solenoid vtec head with a p28 safely and effectively is unbeknownst to me.
Xemu
10-18-2006 04:29 AM
