D17 Valve Cover Swap on D16Y8
Old Mar 9, 2011 | 06:11 AM
Shaguar47's Avatar
Default D17 Valve Cover Swap on D16Y8
Been following the D17 on d-series and some parts of honda-tech and I found out last year the the valve cover will bolt right up to our d16's without any problem. I'm in the mood for a small project to spice up my d16 so here we go. You only have to plug up the dipstick hole next to the oil cap since it's located differently on the d17's. It also yields a much larger blow-by opening than the D16 (perfect for boosting down the road). I always sorta like the plastic cover that goes over the coil wires on the valve cover that either says "Honda" or "Honda Vtec". I've been doing some research and to make my d16 stand out a bit, I'm going to attempt.
Thanks to my friend Mackie (4norzn), he handed me a d17 this past week for free so I think I'm finally gonna try this out! Here are some pics of what I'm talking about.
Standard D16Y8 Cover:
Standard D17A2 Cover:
D17A2 Blowby Opening (so much bigger than the D16) *EVIL GRIN*
Comparison Shot of the size differences:
I'll update pics as I go:
Old Mar 9, 2011 | 06:21 AM
Shaguar47's Avatar
Default Re: D17 Valve Cover Swap on D16Y8
In order to do this, I'm gonna need the following parts:
- #6 Cover Assy. Engine Wire Harness (32120-PLR-000) *Get the PLR version if you want it to say HONDA VTEC*
- #8 Holder Assy. B, Engine Harness (32128-PLC-000)
I'm also wanting to see if I can track down the coil packs and possibly take them apart to fit my D16 spark plug wires under them. This will give a clean look and disguised look. Why not just convert to Coil packs and call it a day you ask? Nah, not interested. I'm a cheap bastard.
Old Mar 29, 2011 | 04:34 PM
Shaguar47's Avatar
Well got the head apart and the valve cover off, here's what I'm working with. A d17A1.
Old Mar 30, 2011 | 01:15 AM
lordhelmet1584's Avatar
What exactly is the point of this? Are you going to be reusing the wire cover?
Old Mar 30, 2011 | 04:24 AM
Shaguar47's Avatar
Yes, I'm wanting to use the D17A2 wire cover which say Vtec on it. It's different and I honestly haven't seen it on another civic unless they've done a D17 engine swap. It's nothing big, just a small little project I'm working on for the community.
Old Apr 3, 2011 | 11:28 PM
I have one in my civic... The plastic will always get to looking crappy so you need to keep it treated to look nice. I'd much rather just have to deal with keeping the valve cover clean.
Any updates?
Old Apr 25, 2011 | 09:08 AM
Shaguar47's Avatar
D17 Valve Cover fit perfectly just as expected and I'm loving the chrome cover stud covers that the 7th gen civics have. No oil leaks, nada. Only thing I need to do was plug up the dipstick hole with is right beside the oil fill cap. D17's have their dipstick going through the valve cover versus any other d16 where it's off the side of the block.
Gonna stop by lowes after work and get a bigger hose to run the blowby opening to the air intake.
Old Apr 25, 2011 | 09:34 AM
dem0nk1d's Avatar
i think this would be a good option if you ran the Carhackers coil conversion setup.
Old Apr 25, 2011 | 10:10 AM
Shaguar47's Avatar
I've considered going with coil packs but can't see the reason to get rid of the dizzy setup. Are they any performance gains from it?
Old Apr 25, 2011 | 10:51 AM
dem0nk1d's Avatar
http://pc.car-hacker.com/dsdd/dm/dmen.pdf
by moving over to the coil on plug setup you don't have to worry about the wear parts that any distributor system would have. Which is the rotor and cap. Also by having the coil on plug application you're able to have a good constant spark. This setup beats the stock system, by not having moving parts which is always good. But it's a little pricey.
Old Apr 25, 2011 | 11:07 AM
98civdx's Avatar
Master Detailer
It's very expensive. A honda ecu cannot run them.
You would need to step up to a motec/ AEM EMS. Which are far from cheap.
Gains, sure. Worth in your case. Not likely.
There's noithing wrong the stock setup.
Old Apr 25, 2011 | 11:16 AM
gentek1145's Avatar
Solve the crankcase ventilation tube issue?
Old Apr 25, 2011 | 12:25 PM
dem0nk1d's Avatar
I think the carhacker setup uses the factory ECU. Unlike the AEM COIL setup which needs the AEM ecu. I could be wrong but i think the Carhackers Coil setup is for the factory unit.
Old Apr 25, 2011 | 12:26 PM
dem0nk1d's Avatar
also if you were to convert over to this system, your engine should be putting out some major power. other than that it's not logical
Old Apr 25, 2011 | 12:35 PM
98civdx's Avatar
Master Detailer
After seeing the link, yea It runs the stock ecu, and still has a distributor.
That's not the setup I was talking about.
The setup my friend runs on his car is completely different, and cost a lot.
If the price is right, and it does do everything they say it does, it could possibly be a worth while upgrade.
Old Apr 29, 2011 | 06:59 AM
Shaguar47's Avatar
I still don't know, not looking for any gains in the my ignition strength. Stock unit will suffice for now but I'll always consider. The cost is the number one thing that is holding me back from doing such a thing.
Old May 4, 2011 | 04:51 AM
Shaguar47's Avatar
Got the parts in yesterday and because it was raining, I was unable to get good pics but I was able to fit it and it looks so different. Hood Clearance is like a few centimeters but no rubbing so far. Love it! I revised the top of the page as only 2 pieces are needed if anyone is interested. I'll post pics up later if the sun decides to pop out.
Old May 4, 2011 | 07:57 AM
Shaguar47's Avatar
Picture is off my blackberry but it gives you the idea.
Old May 4, 2011 | 09:22 AM
taylourmaid's Avatar
looks good and different... what about painting the metal valve cover underneath and having that black plastic over it?
Old May 4, 2011 | 09:36 AM
evildc2's Avatar
Not to sound like a dick or a sarcastic hater...... but doesnt the Y8 VC look better??
or even the z6 with the VTEC logo on ??.........just a dumb comment
Old May 4, 2011 | 09:56 AM
Shaguar47's Avatar
No they do look better, but anymore that's all you see under everyone else's hood! This is just to be different for the sake of things.
Old May 4, 2011 | 09:58 AM
Shaguar47's Avatar
I'm very much wanting to pull the VHT wrinkle red off the shelf this weekend and give it a nice paint job and keeping the cover on there black. I've only seen one other A2 painted this way and it looked good.
Old May 4, 2011 | 10:02 AM
evildc2's Avatar
I see, if been different is your goal.........then is looking legit
Old May 4, 2011 | 10:03 AM
Shaguar47's Avatar
Here's an example of what I'm talking about.
Old May 5, 2011 | 12:28 AM
What are the specs on that 7th gen? Its got a different brake fluid reservoir, resonator, and air filter box than usdm 7th gens. The freon port is in a different location as well. Did that valve cover come wrinkle red stock?
